aem watermeth problem
Old Jul 7, 2012 | 02:50 PM
japancrx90's Avatar
Default aem watermeth problem
i have a code 2 error on my aem meth kit, its between the pump driver and the coontroller, y try test button but there no spray , some of you have ever get this problem? i have 12 volt on my orange wire and on my batterie wire
Old Jul 7, 2012 | 04:06 PM
japancrx90's Avatar
[quote name='japancrx90' timestamp='1341701455' post='21841706']
anyonw had this king off problem, the kit run good for 6 month, can my pump can be defect? controller?
Old Jul 7, 2012 | 06:02 PM
japhethwar's Avatar
Apply ground to the black wire on the pump, if it sprays the pump is good. Then go to the controller. Apply ground again to the pump wire. If it sprays, the wiring is good. Only thing left is a faulty controller. Call Aem's tech line, they provide excellent customer service. My flow sensor failed after about 2 months, I sent it in and they fixed it and sent it back in about a week. No charge. If your controller is bad check your wiring carefully. Bad grounds will kill the pump driver quickly.
Old Jul 7, 2012 | 09:54 PM
japancrx90's Avatar
humm i chek it completely tonight, my pump was srcap, my bearing are all going, they make noise when the pump turn, i open the pump, there was a little spring that was broke on the brush off the motor, i finnd little spring that make the job, but i can ear the bearing are so loud, i open the other side off the pump, there was corrosion on the bearing, i only run distilled water, the pump vas the new black aquatec,only used 6 mouth, those pump are not very tuff i think
Old Jul 8, 2012 | 08:04 AM
Thunder-rush's Avatar
I had the same problem..One of the brush springs was rusty and broke and the bottom bearing seized. Apparently this pumps are not completely sealed and if you install them upside down with the cables going up and take water due to rain or puddles theres no way the water to drain out and the pumps fail due to rust. I bought a new one and sealed it with silicone. Lets see if it holds up.
Old Jul 8, 2012 | 08:12 AM
japancrx90's Avatar
i twist a little spring, i turn again , but the lower bearing is scape i oiled it, i order another pump, but i want to drag racing next sunday, if i dont have my new pump i will run the old one , scuse me for mybad english
Old Jul 9, 2012 | 04:25 PM
camuman's Avatar
Just mod the tune for no meth and run safe till the new pump gets in.
Old Jul 10, 2012 | 08:53 AM
japancrx90's Avatar
i will have my new pump tomorrow, but there is lot of people that blow the pump?
4U2NVmyS2K
Feb 10, 2015 07:24 PM
siadam
Mar 10, 2010 06:56 AM
phils2k
Aug 20, 2009 04:10 PM
JoeyBalls
Jul 29, 2009 12:03 PM
sbrodacz
Mar 23, 2009 03:36 PM
