Sponsored by: CARiD
View Poll Results: Which battery would you choose?
Optima
37.45%
Odyssey 680
37.45%
Other Dry Cell/Lightweight Battery
25.09%
Voters: 275. You may not vote on this poll
Battery Replacement
Old May 20, 2010 | 11:08 AM
  #41
CourageOO7's Avatar
Originally Posted by iam7head,Jun 16 2009, 01:09 AM
go to walmart to check out those slim motorcycle battery, it's not as fancy but it's very reliable and cheap
I agree 100%. RX-7 guys have done this for years with the rotary. If you want a lightweight battery, a motorcycle battery is money. HOWEVER, remember they won't have the cranking amps of a regular battery. So, life is decreased but it's a far cheaper alternative to a dry cell.
Good luck!
Old May 20, 2010 | 12:08 PM
  #42
4forall's Avatar
The ETX16L looks pretty spiffy to me. Size and weight difference.
Just curious on the CCA difference. Havnt looked at my battery in a while lol.
Old May 20, 2010 | 12:27 PM
  #43
21337R's Avatar
I <3 my PC680
Old Jun 27, 2010 | 11:14 PM
  #44
21337R's Avatar
LOL mind = blown
For the past minute I couldn't understand WTF was going on. Then I realized that someone must have voted and that bumped the thread up.
I was like "uhh I posted that a long time ago, how could it be at the top? WHERE AM I? did I just travel back in time?,etc"
Old Jun 28, 2010 | 02:56 PM
  #45
ronac's Avatar
+1 for the Deka ETX16L
Works great and I've never had any problems starting. I considered the PC680 too but a local member had one and had problems due to the colder weather. I'm glad I chose the Deka over the Odyssey.
Old Jun 30, 2010 | 07:44 PM
  #46
Suzuka_Joe's Avatar
i still have my battery from 2002 in my car. Hasn't died yet
Old Jun 30, 2010 | 09:51 PM
  #47
R3DS2K's Avatar
Originally Posted by iDomN8U,Mar 12 2010, 08:13 AM
you don't want to go to far out of the OEM spec for CCA since the alternator is cored to charge the battery with a specific CCA
So the Odyssey 925 will be overkill for your alternator and if you go for short drives will cause issues.
cca has nothing to do with the alternator and charging system. you can run a battery with more or less cca without much issues. you can run a battery with even less cca than what is oem if the weather isnt too cold. cca is only need when its at a certain temp and lower
Old Jul 1, 2010 | 06:47 AM
  #48
leo520's Avatar
My OEM battey can't start it up when is 30 or under degrees..
summer it's all fine..
n my car's 07.. now i am looking for new battery.. donno what to get thought..
Old Jul 1, 2010 | 09:22 AM
  #49
shadwsndst's Avatar
The Odyssey PC680 has lasted me more than 2 years with the only issue being that it doesn't like to sit for long periods of time un-used (I went 2 weeks without driving my car). The car is garaged in socal so I don't have to worry about cold starts. I have 800 watt amp that powers my component speakers and it runs great. The battery doesn't like to run accessories when the power is turned off for more than 5-10min, and forget teaching people to drive stick in your car (not that you want to do that...) but the battery has maybe enough juice to fix three stalls within a 10min period.
I have the PasswordJDM anodized carrier and it cleans up the engine bay nicely.
Old Aug 9, 2010 | 08:05 AM
  #50
Mistman's Avatar
I went w/an Optima red top in the trunk. I have a yellow top that goes between my rock crawler and tractor that I've had for over 10 yrs and it still cranks the old deisel even after sitting for a couple months. I have a red top in my Toy pick up, can't go wrong w/an optima. They are heavy but I cut a lot of weight from the car (no top or motors, aftermarket full exhaust) so it's a wash really. Plus having the heavy turbo up front I figured it would even the weight out a bit puting the batt in the truck. Works out well and is relatively easy to do.
