Sponsored by: CARiD
Berk Technology High Flow Cat - Metallic Substrate
Old Jan 10, 2008 | 12:50 PM
  #111
Bryan@BerkTechnology.com's Avatar
Former Sponsor
Originally Posted by JmanS2k,Jan 9 2008, 02:41 PM
does the berk hfc mate with the asm 60 without issue?
As long as the 60mm is build correctly then yes it will mate. The 70mm is made very far off the factory centerline of the exhaust which is why there's an issue with that one. If the ASM 70mm was close to correct then there would be no issue with that exhaust.
Old Jan 10, 2008 | 01:27 PM
  #112
LostMotion's Avatar
Just get under your car and look at the very back of the tunnel, if the 60mm is within 1/3 to 1/2 inch on the driver side then it probably won't work.
Old Jan 23, 2008 | 10:16 PM
  #113
Series10's Avatar
just placed my order. Thanks!
Old Jan 23, 2008 | 11:32 PM
  #114
McHeizer's Avatar
Originally Posted by carrera4,Jan 3 2008, 04:11 PM
Basically the Berk cat does not follow the same path as the stock cat. The exit ends up between 1/4 and 1/2 inch to the driver side and about 1/8 inch higher that the stock cat.
If you have that amount of clearance with your setup now, you will be fine.
I can confirm that (roughly, didn't measure it)
But I can state it clears with my T1R 70 V2
Old Jan 26, 2008 | 08:08 PM
  #115
Series10's Avatar
got my HFC within 3 calendar days, wow!
Install was a breeze and I am very happy with the results.
Thanks!
Old Jan 27, 2008 | 07:32 AM
  #116
Reddog21's Avatar
Great thread and sounds like a great product.
I am seriously considering placing an order but wanted to see if anyone/ Berk has had fitment issues installing the HFC on an AP2 with Mugen Header/ Exhaust?
Old Jan 27, 2008 | 09:28 PM
  #117
replica's Avatar
what is the power gain for the HFC over the stock cat?
Old Jan 28, 2008 | 12:47 PM
  #118
Former Sponsor
No problems. The only exhaust that is f'ed up is the ASM 70mm. The ASM exhaust fitment is crap and doesn't play well with our HFC.
Old Jan 28, 2008 | 02:17 PM
  #119
LostMotion's Avatar
I believe the issue is that the AP1 and AP2 stock cats are slightly different and the aftermarket cats are derived off the AP1. This isn't verified yet, but I should know for sure in the next two weeks. It's only a 10mm difference though so most people won't have a problem.
FYI all, the Berk is good cat for the money, just didn't work with my system.
Old Jan 28, 2008 | 04:44 PM
  #120
RadioZero's Avatar
no issues on my 2007 model with Berk HFC and OEM header/OEM cat back.
