Sponsored by: CARiD
Which calibration to use?
Old Apr 22, 2016 | 03:27 PM
06s2kid's Avatar
Default Which calibration to use?
If i get a k&n fipk intake, and a test pipe, what calibration will i use?
Old Apr 22, 2016 | 03:47 PM
JUSTINTHECOASTIE's Avatar
Using what?
Old Apr 22, 2016 | 07:40 PM
jakescakes's Avatar
flashpro?
Old Apr 22, 2016 | 07:51 PM
06s2kid's Avatar
Yes flashpro
Old Apr 23, 2016 | 03:56 AM
Chuck S's Avatar
Used the Gernby tune you'll get with minimal effort and minimal cost. I left the OEM calibration alone until that process was done. Took a couple of Saturdays based on my schedule. Worth the time spent.
-- Chuck
Old Apr 23, 2016 | 05:00 AM
MattZ28's Avatar
+1 for Gernby. You won't find a better mod for your car...his tuning skills are top notch and at a price that can't be beat.
Old Apr 23, 2016 | 06:11 AM
06s2kid's Avatar
How much does he normaly charge? I have to datalog first right?
Old Apr 26, 2016 | 04:59 AM
QuePasaKielbasa's Avatar
In the process of this myself. Cost is $99. He will send you 7 different calibrations which each require 3 data logs. So 21 "pulls" in total. He makes tweaks, typically sends you a few more calibrations for testing, couple more tweaks and then you have a custom tune for your specific vehicle, elevation, climate, etc.
In the meantime you can load the Toda Tune. Thats what i'm running. Gernby refers to it as the "test pipe" tune.
Old Apr 26, 2016 | 07:00 AM
Chuck S's Avatar
Yep, that's the procedure. You don't do anything until you get the diagnostic calibration set.
None of the calibrations Gernby sends are driveable. They' diagnostic tunes are only loaded for the short period of time it takes to make the 3 pulls or runs after which you save the data and load the next one and make 3 runs until you've gone thru all 21 (or more). Put the OEM tune back in the ECU. You'll be emailing back 7 data files which he'll analyze and send another set of 7. Takes maybe 3 sets of data. You'll get a Final Tune at the end of the process.
Took me 3 weekends for this but it was all my delay, not his. Return data came the same day sometimes.
-- Chuck
Old Apr 26, 2016 | 07:23 AM
Mijae007's Avatar
Unless hondata fixed the tables in the knock ignition limit high tables do not use this tune. You WILL hear audible pinging at high loads in low rpm.
czirrfb3
Feb 20, 2019 05:42 AM
powerpunk5000
Dec 13, 2014 11:19 PM
civic_redline
16
Nov 18, 2012 12:39 AM
Neuman04
Nov 10, 2010 09:47 PM
dsm_mikey
Nov 16, 2008 09:26 PM
