Sponsored by: CARiD
CEL because of tp with CEL fix
Old Jul 30, 2010 | 01:43 PM
slickback's Avatar
Default CEL because of tp with CEL fix
I just put in an invidia 70mm tp with the CEL o2 sensor fix and it threw the code 0420 which is for the catlyitic converter. I was wondering if anyone else has had this problem and if there is a way to fix it, thanks.
Old Jul 30, 2010 | 01:48 PM
ahrmike's Avatar
https://www.s2ki.com/forums/index.php?showt...0&#entry4560256
from UTH FAQ/DIY
Old Jul 30, 2010 | 02:06 PM
slickback's Avatar
I don't think thats the problem because the code is not for the O2 sensor it's for the cat
Old Jul 30, 2010 | 03:34 PM
suzuka-blue-s2k's Avatar
You don't have a cat anymore man, so it will throw that code when you no longer have it. Some of our cars still throw the CEL even with the fix. Get some of those O2 simulators and it should fix your problem.
Old Jul 30, 2010 | 03:40 PM
ahrmike's Avatar
The "Cat CEL" is because the secondary o2 sees too much CO (?) and other "bad" gasses that the catalytic converter is supposed to convert. Pulling the secondary O2 a little further back makes the ECU "think" the catalytic converter is still there.
the CEL fix SHOULD & will work if you do it right. You have the AP1, not the DBW AP2 so the ECU is a little less sensitive, like mine.
Old Jul 30, 2010 | 07:28 PM
slickback's Avatar
Alright, thanks yall I appreciate the help
Old Jul 31, 2010 | 03:31 AM
chViETnk's Avatar
i had a invidia 70mm testpipe with cel fix, didnt work at all, added an extra defouler and it got rid of the cel.
dennisp
May 7, 2012 05:20 AM
sybar
Oct 27, 2010 01:03 PM
Brian Si
Jan 3, 2010 07:31 PM
funat9000rpm
Sep 23, 2008 07:42 PM
KenGPW
Jun 5, 2004 12:57 PM
