Sponsored by: CARiD
Cheaper alternative to BBK?
Old Aug 6, 2009 | 11:56 AM
supahman04's Avatar
Thumbs up Cheaper alternative to BBK?
If Im not mistaken there is a JDM 5 lug integra. And they do make BBK for them. But as you know as soon as something is associated with an S2000 the price skyrockets!!
But as long as the BBK for the teg' is a 5x114.3 offset, then in theory shouldnt it work???
Old Aug 6, 2009 | 12:14 PM
mwilly00's Avatar
The caliper mount points are probably not the same. Just a guess though.
Old Aug 6, 2009 | 01:09 PM
kevos2k's Avatar
mounting points are different... i tried to mock up some integra type r calipers on my car they would not fit without modification
Old Aug 6, 2009 | 01:47 PM
integlspwr's Avatar
and isnt s2k calipers bigger than ITR calipers
Old Aug 6, 2009 | 03:40 PM
GPW03's Avatar
What about NSX brakes? Not sure if it will workthough?
Old Aug 6, 2009 | 04:13 PM
Mor.gan's Avatar
Why dont you make your own? All it takes is a little bit of intelligence...
This is the kit I came up with which uses Wilwood. It keeps the stock rotor btw.
2 x WIL-120-6805 - Brake Caliper, Dynalite, Aluminum, Black Anodized, 4-Piston
WIL-220-6860 - Brake Lines, Stainless Steel Braided, Flexline, Front
2 x WIL-250-6289 - Caliper Mounting Bracket, Replacement, Billet Aluminum
WIL-15B-3991K - Brake Pads, PolyMatrix B Compound, Semimetallic, Front/Rear, Universal, Set
These are all Summit Part Numbers and come out to : $503.06 before shipping and any tax.
So, with the $11.95 shipping and handling charge it would be $515.01 for a Wilwood 4-Piston BBK that uses STOCK calipers.
Old Aug 6, 2009 | 04:20 PM
AFs2k's Avatar
WOW, do you have any pics of that installed?
Old Aug 6, 2009 | 04:34 PM
rioyellows2k's Avatar
I've seen NSX calipers on S2000's so I think it can be done. Doesn't spoon Make 4 Pot calipers for 5 lug Honda's?
Old Aug 6, 2009 | 04:55 PM
phoenix2.2's Avatar
I went onto summit and the part number for the mounting brakets is not found WIL-250-6289
Old Aug 6, 2009 | 05:22 PM
mwilly00's Avatar
I would really love to see this done, however I have doubts that it would be as simple as your making it sound. I'm pretty sure its going to take some kind of fabrication, even with the mounts, to get the caliper to sit perfect both vertically and side to side.
Also its not really a big brake kit if your just changing the calipers, and the calipers would no longer be stock.
