Sponsored by: CARiD
Cheaper alternative to BBK?
Old Aug 6, 2009 | 05:47 PM
modMonkey's Avatar
Cheaper alternative? Upgrade your pads and run larger tires up front
There was a thread a while back utilizing the TL-S brembos - not sure if it was successful. A few guys in Honda Challenge run these on the Civics. You would need custom brackets for sure.
Old Aug 6, 2009 | 06:02 PM
skem's Avatar
in for pics of the $500 wilwood setup.
Old Aug 6, 2009 | 10:50 PM
S2Kage's Avatar
So, with the $11.95 shipping and handling charge it would be $515.01 for a Wilwood 4-Piston BBK that uses STOCK calipers.
That makes no sense. How is a wilwood 4 piston BBK a STOCK Caliper? ...
Old Aug 7, 2009 | 03:40 AM
GPW AP2's Avatar
I am pretty sure he meant to say stock rotors, not calipers.
John
Old Aug 7, 2009 | 06:11 AM
PhantomAP1's Avatar
^^ Yeah, he mentioned "stock rotors" for, so the stock "calipers was just a typo.... I'm sure anyone reading that, could figure out what he meant...?
I would go for the Willwood set-up, if I had proof that the brackets lined the calipers up to the rotors properly. (Pictures and such.)
Old Aug 7, 2009 | 06:48 AM
TrackStar's Avatar
In for pics!!
Old Aug 7, 2009 | 06:56 AM
slates74's Avatar
Get the last generation v6 manual accord front calipers. They have more pad surface and you can use your oem rotors and mounting points.
Old Aug 7, 2009 | 11:20 AM
nismo4life's Avatar
The JDM DC5 Type R uses a different mounting size than the USDM RSX Type S. The RSX-S and the S2000 and I believe the TSX as well all use the same calipers/brackets/pads. The SPOON caliper kit someone mentioned before will bolt on to all 3 of these with the same bolt spacing so the DC5R brakes you cannot run, you need to change the whole hub when you do the swap on the RSX. The TL-S Brembos however I don't know....anyone think about RL? Its a Honda 4 pot caliper and its smaller than the brembo calipers.
Old Aug 7, 2009 | 11:21 AM
nismo4life's Avatar
More info? Any idea of the surface area difference?
Old Aug 7, 2009 | 11:24 AM
drewmob's Avatar
https://www.s2ki.com/forums/index.ph...f=193&t=721223
