Comptech intake install help?
I bought this intake used off of another member on the site. I have the written directions which they were so kind to give to me, i was wondering if anyone had any pictures of the installation? my main issue is with the mounting of the box, I think I can figure out everything else as long as I am not missing any parts
I have found two mounting points, but am unsure about the best way to mount the box, and if there is a third location for the bolt. the location on the passanger fender is hard to get to, I was wondering how you guys did it? I read somehwere that there should be a metal piece behind the hole that you can screw into, I dont have a metal piece if that is the case
here are the pictures of what I am talking about:
this is the back location to mount the box (using the stock airbox location), is there a front location
this is what I have
anyhow I have someone who is an actual technician to help me do the install, I just want to make sure I have everything before I go to him.
I order some filter cleaner too
this is what I have
I know i need to pick up the following:
3 qty 6mm hex bolts with washers
1- 5mm hex bolt with washer
what is an air solenoid spacer?
what does the front box mounting bracket look like?
what is a coolant bypass line?
obviously I haven't installed anything myself so i need a little help here.
If you have the directions it should all be right there for you.
Yes, you are missing the fender liner mount. It also appears your are missing the relocation pieces for the solenoid.
The metal piece with the nut welded on is the new bracket for the front of the box. It replaces the front mount from the stock box location. One of the thick hoses is the coolant line.
http://www.hondatuningmagazine.com/tech/04...take/index.html
Curated Content Editor
Jun 1, 2017 07:24 AM
