Sponsored by: CARiD
Comptech intake install help?
Old Jul 8, 2008 | 02:24 PM
iwantyourcar's Avatar
Default Comptech intake install help?
I bought this intake used off of another member on the site. I have the written directions which they were so kind to give to me, i was wondering if anyone had any pictures of the installation? my main issue is with the mounting of the box, I think I can figure out everything else as long as I am not missing any parts
I have found two mounting points, but am unsure about the best way to mount the box, and if there is a third location for the bolt. the location on the passanger fender is hard to get to, I was wondering how you guys did it? I read somehwere that there should be a metal piece behind the hole that you can screw into, I dont have a metal piece if that is the case
here are the pictures of what I am talking about:
this is the back location to mount the box (using the stock airbox location), is there a front location
this is what I have
anyhow I have someone who is an actual technician to help me do the install, I just want to make sure I have everything before I go to him.
I order some filter cleaner too
Old Jul 8, 2008 | 02:28 PM
I know i need to pick up the following:
3 qty 6mm hex bolts with washers
1- 5mm hex bolt with washer
what is an air solenoid spacer?
what does the front box mounting bracket look like?
what is a coolant bypass line?
obviously I haven't installed anything myself so i need a little help here.
Old Jul 8, 2008 | 06:06 PM
bump for some help
Old Jul 9, 2008 | 04:56 AM
bump for help..
Old Jul 9, 2008 | 05:06 AM
Ubetit's Avatar
If you have the directions it should all be right there for you.
Yes, you are missing the fender liner mount. It also appears your are missing the relocation pieces for the solenoid.
The metal piece with the nut welded on is the new bracket for the front of the box. It replaces the front mount from the stock box location. One of the thick hoses is the coolant line.
http://www.hondatuningmagazine.com/tech/04...take/index.html
Old Jul 9, 2008 | 07:27 AM
thanks for the info, looks like I will need to rig something together. also thanks for the link, i really appreciate it
Old Jul 10, 2008 | 01:53 AM
SOHCmyDOHC's Avatar
Contact Nate at CT engineering (comptechs new name) if you want to go the easy route to get all the parts you are missing. You are missing quite a bit I must say.
Curated Content Editor
Jun 1, 2017 07:24 AM
puffxy
Bay Area For Sale
Oct 14, 2010 01:57 PM
common reactor
Oct 29, 2006 07:54 AM
Irace4Kimchi
Apr 8, 2006 11:50 AM
TwistedS2k
Dec 3, 2004 05:02 PM
