Depo tail lights Hyper flash
hey guys, i had the same issue
- the lights are plugged in wrong. You need to reverse which cables you have plugged into your lights (it's the far plug and one of the centers). I did trial and error when i was installing them and that's how figured it out.
You'll need a set of hyperblink fixers. I've fixed the Depo tails before.
Regular ones: Turn Signal LED HyperBlink Fixers - $4.00 : JS2K.com!
Premium No-Splice Harnesses: Premium Plug and Play Turn Signal LED HyperBlink Harness - $14.99 : JS2K.com!
How quickly will these ship after ordering? Also I’ve noticed lots of people mentioning hyperblinking but no mention of blowing fuses. Mine are blowing the blinker fuses/dash light fuses. Anyone else having this issue as well?
Hey menacexp;24612496 do you have pictures of what you are referring? I am having this hyper flash only when I put the signal but on hazards it works fine. thanks for the help.
might be too late to reply but I just picked me up some depo tail lights from a friend. And I was having the same issues. Everything plugged in and I had hyper flash when using the turn signals and only 3 led will light up, but when I use the hazards they all work normally. And then from all the info I got from the forums I fixed it!!! So what I had to do is for the front turn signals I took out the led that I had in it and put a regular bulb in. For the side markers I don’t have a bulb since I’m wide body. But I’d you are using your side markers I would try and put a regular bulb in that and not a led. Then I put a resistor on both side for the turn signal (rear) and test it and everything works! No hyper flash, no 3 led light up. Everything works as it should. Hope this helps.
