diy eibach pro kit spring install
i just bought eibach porkit springs for my s2000 and cant seem to put my finger on a diy page that has it on it.(and yes i have looked for a good amount of time) so i was wondering if anyone could help me with this. any help would be appreciated cause im planning on doing it saturday and need some instructions
1. take off wheel
2. remove strut
3. compress spring with a spring compressor then remove top nut so that spring can come off
4. put new spring on old strut, nut it back together (yeah yeah it sounds dirty i know)
5. put old strut back on
6. put wheel back on
7. next... repeat.
Oh somewhere in there you gotta jack the car up, that usually helps !
2. remove strut
7. next... repeat.
i put the car down on it's weight on the installed wheel and then torqued to specs, some are harder to get to than others but all are accessible and can be torqued on the ground rather than on a jackstand and a jack pushing up...
Oh and pre-loading is not the hardest. Removing/Installing the rear driver side coilover is the hardest.
The method I used to pre- load is... hand tighten all the nuts/bolts, while the car is on jackstands, place a jack under the hub assembly, jack up until the car is lifted off the jackstand. Torque.
complete installation for eibach springs with pics is here
http://www.s2000turbo.com/index.php?option...id=92&Itemid=27
Enjoy!!!
Enjoy!!!
