DIY Elbow Pad Wrap
I thought of spray adhesive, but if there was any reason I wanted to remove it I would not be able too. Figured the way I did it will make it removable. If things get loose I can just unwrap it and do it again
Good job on the install! I usually take the original cover off as the new one sticks better to the plastic. Also, a tip about the door sticking. When you have the pad upside down, you'll notice a plastic ridge towards the front. This is more or less a high water mark for the door. You should trim any material just before it and not have any go over the ridge (like the oem leather). This way the door doesn't snag on anything.
Originally Posted by Dando' timestamp='1317570777' post='21032097
Just did mine, wish I read this first! glue didn't stick the greatest but still works
