Sponsored by: CARiD
Dyno'd my 06
Old Sep 4, 2008 | 06:59 AM
TheLast13's Avatar
Default Dyno'd my 06
Ive been searching for a baseline for the 06 newer cars and havent been able to find one, so I thought Id do it and post it up.
Completely stock other than diff 17 inch wheels. Also it was 92 degrees out in the sun.. no fans blowing either
Old Sep 4, 2008 | 07:07 AM
roflitzjinno's Avatar
seems about normal. ive seen baselines ranging from 190whp to 205whp. it strictly depends on the dyno youre using i believe.
Old Sep 4, 2008 | 07:10 AM
rudeS2k's Avatar
+1
Old Sep 4, 2008 | 07:13 AM
Mother's Avatar
No torque graph?
Old Sep 4, 2008 | 07:35 AM
TheLast13's Avatar
Yea the guy didnt have the correct part he needed to clip to a coil pack. He said he needs that signal to pull torque. Thats also why the graph reads MPH instead of RPM's..
it was a free dyno run.. hard to complain..
Old Sep 4, 2008 | 09:07 AM
GPW AP2's Avatar
It it also displaying Power (HP) on the graph which is uncorrected and will show a little higher numbers.
John
Old Sep 4, 2008 | 12:27 PM
TheLast13's Avatar
how does that A/F ratio look?
is it time for hondata reflash?
Old Sep 4, 2008 | 01:32 PM
s2000Junky's Avatar
Actually it looks confusing to me. I guess you started just a bit before vtec, but that pre vtec afr looks super lean in the 16.1 range. Is it possible that you slowly pushed the throttle down so that the ecu was still in the partial throttle fuel map durring the pull? But also your vtec afr look quite rich for a stock N/A S. I was kind of suprised to see that now that you mention it. Your afr's are pretty smooth though. It would be interesting to see what they look like from the 2500-4000rpm range and if you hammered down at the start or just pussy footed it. If you could run 13.1 across the board you would likely see 5-10 whp across your entile rpm range, more as your rpms increase in vtec.
Fokker
Aug 2, 2014 02:00 PM
jun1or
Aug 30, 2013 09:39 AM
bgoetz
Sep 16, 2009 12:51 PM
Boofster
Jan 9, 2008 11:48 AM
FASTSIIK
May 8, 2006 07:39 AM
