Sponsored by: CARiD
ECU reset on 06+
Old Aug 16, 2014 | 10:24 PM
ArmyAliBaba's Avatar
Originally Posted by 1nate7
You should get Flashpro and a proper tune if you really want to take advantage of the test pipe. It will allow you to lower VTEC and pick up a good amount of mid range HP/TQ. Gernby has done quite a few Flashpro e-tunes which is probably your best option.
Working on that flashpro purchase. It's actually next on the list. What do you mean by e-tune? A tune without a Dyno?
Old Aug 17, 2014 | 10:07 AM
rossco's Avatar
Do what is called battery reset procedure. Disconnect both positive and negative battery cables and with them disconnected jump with jumper wire positive to negative. Then turn key to 2 position. This erases all memory in ecu and restarts from factory. Leave like this for 10 min. Then turn ignition off. Now reconnect battery cables. After procedure need to do "idle learn" let car fully warm up till fans come on, then let idle for 10 minutes no loads. Do not touch throttle. Thats it!
This is a normal dealer/manufacturer procedure.
Old Aug 21, 2014 | 05:16 AM
mattstryfe's Avatar
Originally Posted by ArmyAliBaba
Originally Posted by s2k4life_az' timestamp='1404157351' post='23224391
Originally Posted by Gernby
Performance will suffer if you use a larger diameter test pipe than your exhaust. If you have the stock exhaust (60 mm), then use a 60 mm test pipe.
Significant difference?
I'm also curious. Is it a large difference? I still have the 60mm on the rack willing to swap back. I currently have the 70mm on now.
It's very difficult to measure the difference (without a dyno) but scientifically speaking, there is definitely a drawback in using a larger test pipe in this case. Creating any bottleneck in the system creates a host of negative reactions to occur. Whether the drawback is turbulence, a decrease in exhaust gas velocity, or it's effect on scavenging; it's all bad. A smooth transition from larger to smaller (Gernby's design I think) has shown very good results.
Old Aug 21, 2014 | 06:44 AM
Originally Posted by mattstryfe
Originally Posted by ArmyAliBaba' timestamp='1408256574' post='23290108
[quote name='s2k4life_az' timestamp='1404157351' post='23224391']
[/quote]
As in a 70mm header -> 70mm tp -> 63mm exhaust?
Old Aug 21, 2014 | 08:18 AM
Gernby's Avatar
Former Sponsor
The header collector should NOT be 70 mm for an NA setup. Anything bigger than 2.5" just wastes the scavenging energy that can be generated further down stream. The best performance comes from maintaining the diameter at 2.5" for a few feet, then expanding out. Basically, like the system in my signature.
Old Sep 2, 2014 | 12:28 PM
I don't see it in the sig...explain?
Forziii
Sep 27, 2016 06:51 AM
Back S2k
Nov 19, 2014 04:20 PM
rmk232
Mar 16, 2012 09:15 AM
LegendaryHarry
Apr 13, 2008 10:39 PM
