Sponsored by: CARiD
EMU first setup (CEL On) TPS and VTEC problem
Old Jan 1, 2010 | 11:17 PM
kaissi's Avatar
Default EMU first setup (CEL On) TPS and VTEC problem
Dip switches all off..
Jumpers as follows:
JP1: open
JP2: open
JP3: open
JP4: open
JP5: open
JP6: open
JP7: 1-2
JP8: 1-2
JP9: open
JP10: 2-3
JP11: open
JP12: open
JP13: open
JP14: open
JP15: 1-2
JP16: 1-2
JP17: open
JP18: open
JP19: 1-2
JP20: 1-2
No map selected:
F20C original settings.
As soon as I started the engine.. CEL is on, I put the HIM (Honda Interface Module) I got TPS low voltage, and VTEC Failure???
I installed the latest firmware, I remember 1.06 ?!
I also am using the latest tool, I guess 2. something
Old Jan 2, 2010 | 02:18 AM
andys2000belgium's Avatar
i think jp17 should be 1-2 instead of open
For the tps voltage:
Go to parameter setting -> throttle
Min should be arround 0,23v
Max should be arround 4,49v
And i'me not sure bit i think the firmware should be the same as the tool your using.
Old Jan 2, 2010 | 02:20 AM
kaissi's Avatar
JP 17 is indeed 1-2 ???!!!!!
mm TPS I'll check this and let you know.. so I should put it as manual and enter these values right ?
Old Jan 2, 2010 | 02:26 AM
you should not start the engine ultill you heva the tps in the good value.
just turn the key, but dont start the car.
then look at the parameter throttle screen and press your throttle pedal.
this should show up on the schreen .
now you can save the parameter settings and upload them to your emanage ultimate.
now turn the ignition of and back on and it should be ok
Old Jan 2, 2010 | 02:30 AM
kaissi's Avatar
I will try and let you know what about the VTEC failure !?
Old Jan 2, 2010 | 02:53 AM
put jp17 to 1-2 and it should be solved
Old Jan 2, 2010 | 03:05 AM
and if your using tool 2.something you need to assign the dip switches.
just use 1.14
Old Jan 18, 2010 | 05:09 AM
kaissi's Avatar
I tried the throttle thing, and yes I got the value before turning on the car, as soon as you push WOT... you get the values on the screen, mine turned out to be 4.63 and 0.25v
and then I downloaded it to the EMU.. and made sure the JP17 is 1-2...yet still CEL with 2 codes, the VTEC failure and TPS low voltage ??!!
Where can I download the 1.14 tool and its correspondent firmware ?
toniotran
May 18, 2010 07:24 AM
nicholasbartleet
Mar 3, 2009 04:11 AM
qbmurderer13
Jul 7, 2008 08:53 PM
simonprelude
Feb 25, 2008 02:03 AM
UPR
Aug 14, 2006 12:10 PM
