Extra power on demand...
A cut out would have to be tuned like any other mod for best results. Given the resulting compromises I would just get a good 70mm system as earlier stated. Just how would you use this? Flip it open to get on the freeway then close it? So you get called out by a white Jetta, then what, "hold on dude while I open my cutout"? Too late junior...
A cut-out is primarily designed for track use.
Originally Posted by s2k>delsol,Mar 1 2008, 04:11 AM
could the dimension allow this to be made into a bolt application if given to some experience weilders to directly replace cat or test pipe???
QTP makes down-pipes with this cut-out in it for Evos. I am not sure if they make it for other cars.
Here is one example of the potential gains from this cut-out:
http://forums.evolutionm.net/showpost.php?...46&postcount=40
Cliff notes: 38awhp and 16 ft-lbs gains
I don't understand why some of you are so skeptical about this mod.
Originally Posted by shotiable,Mar 1 2008, 11:17 AM
not to start a flame war or anything... but its just fishy coz its too good to be true and you're overly defending it mr. op. sorry, i'm out of this thread.
