Sponsored by: CARiD
Gas pedal mod
Old Mar 17, 2012 | 07:02 AM
  #21
berny2435's Avatar
thread starter,
do consider that even you are saying that you have to consciously NOT brake like you used to. That might be a risk not worth taking. Properly heal-toe'ing in this car involves short legs and actually braking hard. when you do brake hard, the pedals do line up nicely. Durring Daily driving, rolling the foot/ankle is a better approach if you have wide enough feet/shoes. If you don't practice this, you could also slip off the brake pedal when you don't want to which is also a risk. A wider brake or gas pedal can help the roll approach as well which it looks like you experimenting with.
As a Manufacturing Engineer with over 8 years of experience in multiple factories, I've seen worse, much worse Gerry Rigs and they hold up. You have enough clamping force with the screws you have and as long as those plates aren't tin, I think it will hold for a good while.
at 6'3", 36" inseem and size 12 shoes, I feel I need a either a wider brake pedal or gas pedal as well to do the "roll the foot/ankle" blipping. I think you did the right thing in not doing the brake pedal b/c the force which is used on the brake pedal could lead to issues with a cheesy, clamp on type pedal and the clamp-on with actually move the brake pedal further away from the gas pedal which is not what you want for DD driving.
I think you made the gas pedal a little too wide for my liking. I don't really think I would need that little extended area you created on the bottom left. With my foot positions, I would likely accidently hit that area while braking in normal conditions b/c my leg/knee stays a bit to the side of the steering wheel instead of going directly under the steering wheel so my foot doesn't stay parallel with the brake pedal. If you have others drive your car, they might do the same.
You might just want to try fabbing up another one that is only slightly larger than the gas pedal and find a grippy, direct replacement for the Brake pedal which would involving drilling out the stock rivits. A bit more labor intensive but will get the job done better I think.
Old Mar 18, 2012 | 05:53 PM
  #22
operator207's Avatar
I heel toe all the time in my daily commute. Even with dress shoes on. This is the easiest and safest way I have found.
Jam you heel into the corner that makes up the floor and trans tunnel by the throttle. This gives you a good pivot for fast braking. turn your foot left to the brake pedal having the ball of your foot on the brake pedal. If you want gas, foot is straight up, you push. If you want brake, turn your foot 45 degrees to the left, and mash. Pointing your toe a bit if you have a heel on your shoe. You can get back to your starting position if needed by just jamming your heel into that corner. To blip the throttle while braking, rotate your foot to the right. I can do this at a stop with very light brake pressure. If I need to emergency stop, I instinctively point my foot, so that may be why this is easier for me.
I have been doing this for 3 years now (longer if you count other cars), and not once have I mashed both pedals accidentally at the same time during an emergency all stop.
For the shoes I wear, I wear these for work and these for play. They have the same sole, I like hte combo, but not for heel toe. I can't stand not feeling the ground and these were the best I could do. In in the summer, I wear these for play. I can also heel toe in these with ease.
I thought about doing something the OP did, but found that the "jamming your heel into that corner" worked great for me.
I'm 5'10" and can't dance.
Old Mar 18, 2012 | 06:52 PM
  #23
Arthas's Avatar
Not sure if I like what you have done to your gas pedal, but oh well to each his own, if it works for you than its alright by me
Old Mar 18, 2012 | 07:10 PM
  #24
fernando.'s Avatar
Originally Posted by mister x
Check out the S2000 Prototype at Nurburgring video with Gan San driving. His footwork is pretty good, heel-toe with street shoes no less.
http://www.youtube.com/watch?v=Nl5cF...e_gdata_player
Never seen this, thanks for posting.
Old Mar 18, 2012 | 10:03 PM
  #25
eevan's Avatar
Originally Posted by J-Speed Inc.
Anyone else sketched out by this?
I rode passenger in my car with someone who had 30+ years autox experienece, he was using the heel-toe method within the first few corners. I suggest you change your method before you accidently hit the gas pedal when you meant to use the brakes.
Someone sound the safety alarm.
veyron owners must have a really big problem then:
Old Mar 19, 2012 | 04:34 AM
  #26
takeshi's Avatar
Originally Posted by PierreC
It is certainly due to my lack of mastering heel/toe, but I don't see how you can press on the gas while breaking unless you have a 4 inches wide shoe or brake with your foot completely crooked.
Nope. Spend more time working on your technique and less time blaming the hardware.
Old Mar 19, 2012 | 04:42 AM
  #27
PierreC's Avatar
Especially without a clutch...
Old Mar 19, 2012 | 11:47 AM
  #28
eevan's Avatar
Originally Posted by eevan' timestamp='1332136994' post='21521679
[quote name='J-Speed Inc.' timestamp='1331830839' post='21511513']
[/quote]
i meant, hitting the gas instead of the break by accident haha surprisingly i'm not that dumb yet
Old Mar 19, 2012 | 02:10 PM
  #29
PierreC's Avatar
Originally Posted by PierreC' timestamp='1332160947' post='21522149
[quote name='eevan' timestamp='1332136994' post='21521679']
[/quote]
[/quote]
Old Mar 20, 2012 | 05:18 PM
  #30
g0g3tt4's Avatar
Originally Posted by BEASTMODE
IMO, the S2000 already has the perfect pedal setup for heel toe.
Originally Posted by AdeJong03
heel toeing is far easier in the s than most of the other cars ive driven.
try toe rolling if youre having a problem.
when the ball of your foot is on the brake, roll the outer edge of your foot towards the gas and the outer portion of your heel will hit the gas.
edit: just found this link and it has a good step by step, almost exactly what i was saying
http://www.edmunds.c...-downshift.html
please take that plate off and just practice a little more
Originally Posted by TKim103
this is the dumbest f@#king thing I've ever read on the internet
next to the Audi turbocharger exhaust mod
Congrats and don't let the wall hit you on the way out
How about the negative "You should work on your skills" commenters back up for a moment. Think for a moment that each person isn't built like you and may not move as you do. For moment try to realize that your physical size and abilities may not be his.
I'll give you an example.
Because the steering wheel is not adjustable when I put the ball of my foot on the brake and then try to heel the gas pedal (blip) the steering wheel won't allow me to do it effectively.
So I have to turn my knee to an odd angle which is pretty uncomfortable. Its possible that with time and many tries I could overcome it, but with this fix it might make it easier.
