Sponsored by: CARiD
Gas pedal mod
Old Mar 21, 2012 | 12:55 AM
  #31
2000ths's Avatar
my knee doesn't fit under the steering column very easily either making it very difficult to rotate my foot. I still haven't found an ideal position for heel-toe on this car...
Old Mar 21, 2012 | 04:25 AM
  #32
ZDan's Avatar
You shouldn't be blipping the throttle with your *heel*. More like the right side of your foot. Heel/toe is a bit of a misnomer...
Old Mar 21, 2012 | 04:40 AM
  #33
takeshi's Avatar
Originally Posted by g0g3tt4
How about the negative "You should work on your skills" commenters back up for a moment.
This and the seemingly ubiquitous "mod first" mentality around here are the reasons for my reply:
Originally Posted by PierreC
It is certainly due to my lack of mastering heel/toe, but I don't see how you can press on the gas while breaking unless you have a 4 inches wide shoe or brake with your foot completely crooked.
OP has not stated that the OP has the same problems you're describing but has clearly indicated that the OP hasn't mastered heel toe. IMO, rather than jumping to mod the OP should continue to work on it. There's nothing wrong with modding but one should definitely make sure that skill isn't the bottleneck first.
There's nothing negative about promoting the building of one's skill set. The way the suggestion is presented can certainly be negative though.
There are a lot of resources out there on heel toeing and it does take time and practice to get it right. Shoes that allow you better feel can help but they're not necessary. I recall seeing a post (not on this site) from someone blaming their shoes for their lack of heel toe ability. Unless you're wearing Frankenstein platforms or women's heels that's really not a valid excuse IMO.
Old Mar 21, 2012 | 06:54 AM
  #34
BEASTMODE's Avatar
this. It's more of a roll over with your foot than actually pivoting your heel over on the gas. I guess it depends on how wide/long your shoe is though. Just watch those videos posted and you will see the correct way.
Old Mar 21, 2012 | 08:54 AM
  #35
aresk3b's Avatar
I just BENT a little the gas pedal BY HAND.
Why don't you try it?
Old Mar 21, 2012 | 10:34 AM
  #36
g0g3tt4's Avatar
It's not really about my problems, but taking a wider view that encompasses more than your skill set or physical abilities.
I can understand why he'd build something like this.
It's like telling a guy he should work on his casting skills, but he doesn't have a fishing pole. How can you work on your heel toe if you can't reach the pedals? Maybe the attachment will facilitate the proper technique and once that is mastered he'll remove it. Kinda like training wheels. All I'm saying is there is more than one way to get things done.
Old Mar 21, 2012 | 04:17 PM
  #37
Chris_Lum's Avatar
It's all about preference. i know just as many people who roll their foot as i do that actually use their heel. i prefer to use my heel!
Old Mar 21, 2012 | 04:40 PM
  #38
NA1NSXR's Avatar
The S2000 pedals are pretty far apart to heel toe with the side of your foot. After I got mine I had to revert to using my heel again and it was a little annoying at first. Still, I would rather just get one of those RAzo pedals rather than do this, if one were inclined to really do something about it.
And quite frankly, people who think the heel is the only proper way to do it need to chill out. As far as I am concerned as long as the shift is done perfectly I don't care how someone does it, they can blip the gas with their faces for all I care. As someone who does both all I'm going to say is that using the side of the foot is much faster, especially if you have to do several consecutively very fast. And sometimes it has nothing to do with preference or performance. Like I said before I only use my heel because the pedal setup. Sometimes I get forced into using one way or the other depending on the shoes I am wearing.
Old Mar 24, 2012 | 03:25 PM
  #39
jaor.s2k's Avatar
lol about the face comment heel and toeing in flip flops is kinda annoying
AWay
Nov 8, 2015 03:49 PM
Smoke13
Jul 18, 2014 08:42 AM
vactor
Jun 22, 2011 07:24 PM
Thomas Guide
May 30, 2006 07:47 AM
The Driver
Nov 11, 2003 09:07 PM
