Headlight Lenses
The lens also houses the black shroud so be sure whatever knockoff set you buy also has the same setup or they won't fit the black housing. I bought a broken set of headlights where the mounting tabs were broke but the lenses were straight.
I just got two brand new OEM headlights off amazon prime with fee two day shipping for $420 each. Don't waste your time and money with all these joke products people recommend. They aren't going to restore the factory perfection. At most the products will remove a little haziness for a short time. Go brand new and you won't be chasing the products.
Oh, come on dude! You just spent $840, instead of $80.
Polishing the outer lens and applying 3M PPF will get then lens 98% as clear as new, and then protect it for life.
What you did is perfectly fine, but not practical for the average person to afford.
I would also suggest to you to apply the 3M PPF so you don't have to spend $840 again in the future.
I agree. $840 is a decent chunk of change for the average person just looking to clean up their headlights.
The product I used made my lights look almost brand new, and have a UV protectant coating that is suppose to last 2 years.
If your lense is not cracked, and as long as the scratches are not too terribly deep, then I see no reason to buy a whole new light assembly. Especially when the new light with be susceptible to the same damage/oxidation.
Its actually possible to polish an old lens to better than factory new. So I gotta agree, polish them, then apply the ppf.
Problem solved. Not a lot of work, not a lot of $.
Just restored my headlights. Spent about 30mins each with 600/800/1200/1500/2000 grit and probably an hour with a scratch remover. Spraying with clearcoat over the weekend. Total cost is about $100 and can easily take care of 5-6 sets of lights. Not factory perfect but can be if we used a polisher. I would say doing everything by hand gives about a 90-95% restoration. Probably cannot tell unless you look at it within 1 foot. Probably will be even less noticeable after the clear coat. I can live with that and $800 still in the wallet.
Edit: found it. invisible mask
