HELP! SIDE MARKER LIGHTS
If they didn't flash with your turn signals, it would be as simple as wiring them through your parking lights. I'm not too sure as to how to wire them to flash with the alarm lights AND retain the turn signal capability. I'm sure there's a way though...
You're going to have to cut the ground wire from the side marker light and run it up to the park light and wire it to the wire that sees +12v when you switch on the park lights.
The side marker will then function as a repeter and will be on with the park lights and turn off when the blinker is on, which i think looks pretty cool.
Then it will function normally when the park lights are off.
Most importantly, this will give you the blinking when lock/unlock the car.
Johnny--2K
May 5, 2004 01:29 AM
