Hid reverse lights?
Originally Posted by seoul2k,Aug 31 2010, 08:02 PM
my led bulbs make it so bright that i don't even have to put my top down (my rear window is tinted) and i can see perfectly
What kind of LEDs are you running? I had 3W LEDs, the good kind...and it still didnt do shit.
Originally Posted by ikeyballz,Aug 30 2010, 12:20 AM
-you have to change one fuse in the panel to a 10A if you don't want to run a harness.
-with the 7.5a fuse in, it blows when you hook up TWO HIDs, works fine with one.
Originally Posted by SgtB,Sep 1 2010, 05:03 AM
DO NOT DO THIS. You are overloading the wire and risking a car fire. NEVER go to a higher fuse rating for any reason.
not very safe. even if your car doesn't burn down it won't be fun trying to replace the melted wiring.
lol that's ridiculous bright!
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
Originally Posted by gernby,Sep 1 2010, 09:48 AM
Honda definitely used larger gauge wire than was needed, so there is going to be a safe margin for increasing current load. Just measure the wire gauge at the connector, and look up the max current load for that size using Google.
Originally Posted by SgtB,Sep 2 2010, 09:25 PM
<Electrician. You can't just take the wire gauge and slap a fuse in it. You need to know the ambient temperature of the wire, and the length before you can calculate the ampacity of the cable. Yes Honda included a safety net, but it would be foolish to remove it. I'm not trying to be harsh, but upping the fuse size is the cardinal sin of electronics. Run a new lead with the proper size wire and a relay.
Fair enough. I apologize if I came off as condescending. I'm permanently stuck in motor-feeder calculation mode apparently. I plan on pulling my trunk lining to give it a good cleaning. I'm probably going to snip and strip the reverse leads to get the gauge value. It would be nice to give a definite amp rating for this thread.
pics not up yet...but a write up to start. pics will be up when a friend uploads them for me!
https://www.s2ki.com/forums/index.ph...&f=22&t=814893
Gernby and SgtB:
Although I couldn't SEE the wire rating, from what experience I have with wires/wire sizing it appears to be smaller than the recommended gauging. It doesnt seem to have resistive heating. I ran it without the wiring harness for a few days (maybe 30minutes over that period) and it was fine, but I do NOT recommend it anymore which I make clear in the DIY. It would probably work fine until a ground gets rusty/loose in which case the resistance shoots up and the amps flowing through go through the roof and fry the wiring. With proper ground/power, it would probably be fine with a fatter fuse. From what I could tell, the only thing blowing the fuse was the initial surge of power required by the HID igniters, not the steady state draw.
