how to check if shocks are still good?
Old 12-11-2009, 02:33 AM
mikesap1's Avatar
Default how to check if shocks are still good?
hey guys, i came upon a set of used koni yellow shocks for sale.. i was just wondering if there is anyway to tell if the shocks are still in good condition by looking at it? is there some way where u push down on the shock with your hand to test if the compression of the shock is still good? i found a set for 300 bucks with about 15,000 miles on them, what u guys think?? buy or dont buy?
Old 12-11-2009, 04:22 AM
pde27's Avatar
the only way to look at them is see if they are leaking, if it looks wet or anything they are bad. the easiest way is if they are on a car you can do a "bounce" test. if you can manage to push the piston with your hand they are for sure bad, but you should not be able to do that
Old 12-11-2009, 04:25 AM
VolkMan's Avatar
first check if there is any oil like fluid around the shock, another way to tell is to push down on it (remove springs of course if its mounted) and it should very smoothly come up...
If it stays down, pass on them!
Old 12-11-2009, 05:51 AM
Wildncrazy's Avatar
HUH? I've always been able to push or pull the piston by hand.
It's not always been easy, but doable. Any roughness in the movement or a big dead spot when you change directions has always been a source of concern.
Old 12-11-2009, 07:05 AM
prancer's Avatar
This is what i have always been told. I usually just compress the shock w/ my hand (springs removed of course) and if it feels smooth going all the way down, and then rebounds smoothly by itself, then there most likely isn't a problem.
Old 12-11-2009, 10:14 AM
pde27's Avatar
i know what you are saying, it would also depend on the shock. some are harder than others. we are all saying about the same thing though
Old 12-11-2009, 10:43 AM
Skatethesea's Avatar
I also bought a pair of Koni yellows which are still sitting next to my TV but my front shocks do not have the adjustment attachments/keys. Is there anywhere to buy them? I was told i could use a screw driver. But I havent really looked at them yet and wont be able to for a while since I am deployed right now. Anyhelp would be great!
Old 12-16-2009, 01:18 PM
iam7head's Avatar
[QUOTE=Skatethesea,Dec 11 2009, 11:43 AM] I also bought a pair of Koni yellows which are still sitting next to my TV
Old 12-17-2009, 09:03 AM
dfvs2k's Avatar
Look for any leaks. I am not sure you can compress the shock by hand, but if installed on the car you can do the rebound test on each corner
kbmass
06-29-2015 03:22 PM
silvershadow
07-01-2013 01:59 PM
smallville160
10-05-2010 04:22 PM
nartnailuj
06-30-2010 09:40 AM
dreamcation
10-10-2004 11:49 AM
Quick Reply: how to check if shocks are still good?
