NRG Hood Damper - Not Vertical?
#31
my NRG carbon dampers did not open the hood fully either, sounds like a design change to me, I bought mine within the last 2 years.
#32
Ok, a small poll to determine if there was a design change or a mismatch at NRG ...
So those of you who have the fully opening dampers,
what is the newest purchase year?
Mine is 08/2009
Mine is 08/2009
#33
These seem to be a solution in search of a problem. Standard setup works fine, costs nothing, and doesn't bend the hood if something goes wrong. Long hood barely clears my garage door when up though!
-- Chuck
-- Chuck
#35
Site Moderator
Mine are NRG, about as vertical as you can get. I got mine back in 06 or 07, can't remember now.
#36
Chuck,
mine worked great for 10yrs without issues. If you have a cooling plate you can only use the hood prop on the max setting which isn't convenient
anyone else buy one recently with the full open position?
#37
My NRG dampers do not open as vertical as the old ones, mine were bought in 2016 I believe. If you are looking for close to 90 degree open on your hood then you should look into SOS, I have these as well and they are as close to 90 degree as you can get. Good luck.
#38
I'm quite sure they changed the design and you cannot buy the vertical ones anymore.
