Possible to change the 6th gear
Old 11-07-2012, 09:53 PM
  #41
Weasel497's Avatar
Originally Posted by faxter18
Nice color combo on those wheels. I average about 30mpg on all highway 23mpg on stop and go.
Thanks!
Originally Posted by Gernby
This is an oversimplification, and could only be true if losses due to friction wend down at higher RPMs. It is true that you can achieve the same speed by running the engine at higher RPMs with reduced load, but the percentage of the total load that actually makes it to the wheels will go down. Basically, the load due to increased friction will go up, so the overall efficiency will go down.
Yes, I was just trying to make the point that it's not ALL rpm based.
Old 11-10-2012, 01:25 AM
  #42
liquid_helix136's Avatar
Originally Posted by Weasel497' timestamp='1352241646' post='22133890
Actually, rpm doesn't play that much of a role in mpg. The reason being is that in a lower gear, you'll be in a higher rpm range, but the engine is also under less load. Think of it like a mountain bike. Depending on the load of the engine, the ecu will be sending more or less fuel through the injectors, no matter the rpm.
Bingo.
Half the guys talking about fuel increasing with rpm are correct, but for the wrong reasons, and I doubt any of them have ever even looked a properly tuned fuel map. For those of you who havent, Im about to blow your mind.
Heres a quick screenshot that I cropped the important parts to.
Y axis is load and X axis is rpm, the two blue parts are my 4200 and 5400rpm breakpoints at the same load. I have 4.77 gearing so thats where my 70mph and 85mph cruising points are at. As you can see, at the same load, the fuel values are actually the same (these are all tuned within 1% of 14.7 AFR) so initially, one would think well if your using the same fuel at 85mph wouldnt you be getting much better mileage than at 70mph because your going 15mph faster while using the same amount of gas? Yes this would be true, but when I speed up to 85mph, the load increases by about half a break point on average, so I do end up using more fuel, and get better mileage at 70mph, so Whiteflash is right, RPM technically doesn't matter, but its the increase in load thats necessary to get over the increase in friction (and wind resistance/rolling resistance if your going faster) that ends up biting you in the ass.
At least thats my non-engineering understanding of it.
Old 11-11-2012, 05:39 PM
  #43
janaka's Avatar
Its funny I had a 76 datsun with an LS1/6spd (t56) and 3.90 gears and I was maybe 1800rpm at 60mph in 6th and that was cam'd, heads etc (400rwhp) I was knocking down 30mpg in that car (granted it was light), in 5th or 4th the milage was not so much lol
Dropping some RPM would be nice to see some incrase for sure but payback would be LOOONG term for sure.
Old 11-13-2012, 02:00 PM
  #44
Alex S2000's Avatar
Interested in this also. Would be nice to cruise at 70mph at around 2,800 rpms. Would get rid of some drone.
Old 11-13-2012, 09:04 PM
  #45
davidc1's Avatar
Hey Alex, I agree. But then why are you always after me to change my secondary gear in my AP1 to the AP2? lol
Old 11-14-2012, 04:24 AM
  #46
Former Sponsor
Gernby's Avatar
Why not just deal with the drone directly?
Old 11-14-2012, 04:48 AM
  #47
AngryTurtle's Avatar
If only there was some sort of mystical product to help with this.
Old 11-14-2012, 05:56 AM
  #48
Former Sponsor
Gernby's Avatar
Originally Posted by Gigdy
If only there was some sort of mystical product to help with this. />
Off-Topic, but the product he would need is a different exhaust. My mid-pipe doesn't reduce drone from the Greddy SE.
Old 11-15-2012, 07:53 AM
  #49
tbpom1003's Avatar
actually S has pretty good mpg
I drove from SF bay area to LA, it was about 400 miles
I fueled full tank (12.5 gallons) before I reset the mileage meter, and my S didn't stop for fueling on the way.
so 400/12.5 = 32 MPG!!!
the bad thing is... our S is damn good and we are the enthusiasts lol
Ebi17
11-05-2011 09:25 AM
paulng180
02-12-2006 08:45 PM
Sideways
06-16-2005 06:54 PM
drchiropharm
10-23-2001 11:32 AM
DavidM
07-16-2001 07:38 AM
Quick Reply: Possible to change the 6th gear
