Sponsored by: CARiD
Rotors
Old Jun 16, 2009 | 01:06 PM
Headchef's Avatar
Active Streak: 30 Days
Default Rotors
Anyone had experience with Centric rotors? Drilled & slotted.
Old Jun 16, 2009 | 01:12 PM
mikegarrison's Avatar
No, no one. You are the first person who has ever asked this question. Glad to see you didn't waste your time searching.
Old Jun 16, 2009 | 02:16 PM
iam7head's Avatar
hehehe
please do try the following too..
"drilled rotor cracking"
Old Jun 16, 2009 | 05:27 PM
Emil St-Hilaire's Avatar
Hi Chef,
I got Brembo,drilled and slotted rotors,had them for at least 3- 4 years,no problems,whatsoever...really them.
Old Jun 16, 2009 | 08:35 PM
s2k dre's Avatar
I had bad experience with the ones i bought! They warped in 5k miles.
Old Jun 17, 2009 | 04:52 PM
Headchef's Avatar
Thanks Emil, where did you find a good price on the Brembos?
Old Jun 17, 2009 | 05:36 PM
jeffbrig's Avatar
I'm using Racing Brake rotors. Only on the car a couple thousand miles so far. I think I paid about $450 for a set of 4.
(and, yes, drilled/slotted rotors are more likely to crack than blanks)
Old Jun 17, 2009 | 05:53 PM
wonderd's Avatar
there is nothing wrong with drilled or slotted as long as its not a cheap brand, but no matter what brand you get, blank, drilled, slotted, there aventually going to crack
Old Jun 17, 2009 | 06:45 PM
iam7head's Avatar
no, no and no
have you seen a oem stock vette drilled rotor cracks? what about spoon? those are quality brand and they too, cracks.
you don't need drilled disk, no modern pad outgas.
less surface area for traction, small thermal capacity doesn't sounds like a performance and smart upgrade to me.
if your goal and only bragging right about a drilled and slotted rotor is that they didn't crack, my oem blank didn't crack neither
they did perfectly fine in SOW under socal summer heat, sure they don't look "racy" but who cares about that
Old Jun 17, 2009 | 08:30 PM
jeffbrig's Avatar
Drilled and/or slotted rotors are a visual enhancement, not a performance enhancement. Anyone who says otherwise is kidding themselves.
While your point is technically correct, there's still more than adequate surface area and traction to engage ABS. The reduced mass and resulting loss of thermal capacity isn't a factor in street driving. It could show up at a track day (particularly for more experienced, and faster drivers), but you're not going to have issues like that on the street.
jackblack
Mar 15, 2011 09:47 PM
mr 280z
13
Oct 28, 2008 08:27 AM
bluesaint
Jun 30, 2006 09:53 PM
Sebring Silvur
Sep 17, 2002 05:52 PM
Moneeb
Jun 27, 2001 10:11 PM
