Sponsored by: CARiD
Shorter Shifter
Old May 15, 2011 | 11:35 AM
s2k aok's Avatar
if going for a shorter shifter a countersunk knob is best as what the majority of us do, a shorter shifter is not a short-throw shifter, as the short-throw changes the pivot point and requires less actual movement, moddiction sells both, so whatever you decide will work out for you.
Old May 15, 2011 | 05:06 PM
corrado_driver's Avatar
I have an axial flow with Cr knob. I have the inside scoop axial flow is still being made they are testing right now Well maybe on hold for a little bit but very soon. I have one of the proto types. NO BUZZ.. also reuses the stock shift rubber thing.
Old May 15, 2011 | 11:56 PM
mister x's Avatar
The key question is, why do you want the shifter to sit lower?
I have both the AxialFlow and the Moddiction with a lot of "seat time" for both, as well as 10 different shift knobs. Depending on your answer, I might be able to point you in the right direction.
CorneringMachine
Jul 25, 2010 06:59 PM
unlimitedpower
Feb 27, 2010 01:45 AM
[AP2-2NV]
Feb 20, 2010 06:39 PM
dparm
Oct 23, 2008 12:15 PM
ojy1207
Aug 2, 2008 09:36 AM
