Sponsored by: CARiD
Spoon & AP2 v2 +15mm Spacers
Old Jul 6, 2018 | 09:26 AM
MrFunk's Avatar
Default Spoon & AP2 v2 +15mm Spacers
Hello all
After some research I'm still left scratching by head.
I believe one of my calipers is sticking and as such am debating just replacing them with the Spoon Monoblock Caliper Set as they seem like a direct fit (as long as they clear!).
I'm running 15mm spacers on my AP2 v2 wheels and curious if they will clear.
I'm fairly confident they would clear AP2 v1 wheels from what I've found online but unsure about v2 wheels.
If you can point me in the right direction or at least just tell me the answer it would be greatly appreciated!
Thanks!
Old Jul 6, 2018 | 03:09 PM
Hfreak's Avatar
I know someone that had them on their car with AP2V3's and the JDM forged AP1 wheels without spacers. This does not answer your question but you should be fine because you have an extra 15mm of clearance.
Old Jul 6, 2018 | 03:25 PM
noodels's Avatar
If you have a recess on your v2s for the studs , all should work out ok.
Old Jul 6, 2018 | 03:36 PM
Hfreak's Avatar
^^^The recess is not deep enough on the V2's but he said he is running them, he must have cut the studs down.
I recently went down this road with hub centric 15mm spacers, they will only work perfectly on the AP2V1 wheels without modification as the clearance is just not there on any other stock wheel.
Old Jul 6, 2018 | 03:43 PM
noodels's Avatar
Cut /grind studs flush accordingly to allow v2
Old Jul 6, 2018 | 03:46 PM
jaor.s2k's Avatar
Not sure if this helps, but I had 20mm spacers up front and 25mm rear spacers on my OEM V2 wheels with no trimming to the studs, just rolled fenders.
Old Jul 6, 2018 | 04:03 PM
Hfreak's Avatar
Looks great with the proper alignment, was going to install some 25mm spacers but just looked too aggressive on factory alignment. I didn't have to roll anything with the 15mm spacers.
Old Jul 6, 2018 | 04:38 PM
MrFunk's Avatar
I may not have been clear in my original post.
I'm already running 15mm spacers with my v2 wheels with no issues and no need for cutting down bolts...
My question was if the Spoon Monoblock Calipers will fit with that set up.
These - Go Tuning Unlimited
Old Jul 6, 2018 | 08:14 PM
Stealth2k02's Avatar
https://www.s2ki.com/forums/wheels-t.../#entry6580272
I believe you will need a 20mm spacer to fit..
Old Jul 7, 2018 | 04:55 AM
MrFunk's Avatar
Thanks! ^^^
I did see that thread but was unsure what USDM ap2 meant. v1 or v2 or both? I found another member who claims he runs AP2 v1 wheels with 15mm spacers and the spoon calipers which would contradict...
