Sponsored by: CARiD
Steering quick release
Old Feb 12, 2008 | 04:23 PM
SortaRican's Avatar
Default Steering quick release
I bought an NRG quick release and short hub for the S. I haven't inistalled it yet, but after taking some rough measurements I noticed that once the new wheel goes on it's going to be too close.
My question is for anyone that has used this combo before. How did it work out, and did you like the fit?
Old Feb 13, 2008 | 08:14 AM
SortaRican's Avatar
Anyone?
Old Feb 13, 2008 | 09:47 AM
neveronlines2k's Avatar
You shoudl be fine I am using a Short Splash hub and Prodrive QR and my wheel sits a little further out than OEM (they are similiar to the NRG) fitment should be about the same.
The only time it shoudl fit closer is when using only the short hub, when not using a QR a longer hub should be used.
Old Feb 13, 2008 | 10:12 AM
SortaRican's Avatar
Thanks I assembled it a while ago and it leaves 1 1/2" for my wheel. Beyond that it'll be closer.
Old Feb 13, 2008 | 02:00 PM
No problem
Old Feb 13, 2008 | 03:15 PM
Apee Two's Avatar
I have the NRG quickrelease and Works bell hub
Its a good setup, fits well (My steering wheel is a Nardi 330mm for size reference)
Old Feb 13, 2008 | 03:47 PM
SortaRican's Avatar
Apee Two:
I can't figure out how to get this to mount with teh srs reel in place. Furthermore I can't remove the reel completely without cutting 2 wires that plug into the back. Did you remove yours in order to make it work?
Old Feb 13, 2008 | 05:42 PM
Apee Two's Avatar
Mine was installed by a shop.
Sorry I can't be of more help on the installation.
Old Feb 13, 2008 | 06:00 PM
SortaRican's Avatar
Found the plug under the dash, now just need to get my hands on a wiring diagram to get the cruise control working again.
If anyone knows the size of the resistor to shut off the SRS light let me know.
Old Feb 14, 2008 | 07:39 AM
NVMY4N's Avatar
you have to hard wire the CC in (if you are using an OEM CC button)
also if you look in the DIY/FAQ section there is an install how to guide that may help you out.
josserman
Jan 7, 2014 12:34 AM
mmhm
Jan 2, 2014 10:50 AM
JuanLuisPadin
Dec 30, 2012 06:24 AM
la_fever323
Oct 9, 2011 09:35 AM
robrob
Jan 8, 2009 07:07 AM
