stock AP1 front sway bar vs CR sway bar
Hi,
anybody know if CR front sway bar is thicker than AP1 sway bar???
I believe AP1 sway bar is 28.2mm
How thick is CR sway bar??
let me know~
thanks guys
let me know~
thanks guys
This should answer your questions about which bars are stiffer and what years they can be found on - Characterization of OE Suspension.
'00-'01 have the stiffest anti-roll bars, front and rear.
See the differences here from another thread:
Spring Rates:
00-01 Front: 218 lb/in - Rear: 291 lb/in
02-03 Front: 240 lb/in - Rear: 230 lb/in*
04-07 Front: 256 lb/in - Rear: 207 lb/in*
08 Front: 274 lb/in - Rear 225 lb/in*
08 CR Front 375 lb in - Rear 264 lb/in*
*values based on % change data, as lb/in specifications not provided by Honda
Sway Bars Overall diameter X wall thickness
00-01 Front 28.2mm X T5.0 - Rear 27.2mm X T5.3
02-03 Front 26.5mm X T4.5 - Rear 27.2mm X T4.5
04-07 Front 26.5mm X T4.5 - Rear 25.4mm X T4.5
08-? Front 27.2 X T5.3 - Rear 25.4 X T4.5
08 CR Front 28.6 X T4.5 - Rear 26.5 X T4.5
According to that you won't notcie much difference between ap1 28.2 and CR 28.6
Spring Rates:
