Stop Tech Brake trouble
StopTech Stage 2 Slotted Kit for the 2000-05 Honda S2000. The kit includes StopTech stainless steel (DOT compliant) front and rear brake lines, three (3x) 500mL bottles of Motul RBF600 (Synthetic DOT 4) brake fluid, StopTech SportStop slotted front and rear stock replacement rotors, and Axxis Ultimate front and rear street performance pads. FOR USE WITH STOCK CALIPERS
Have that set up above... with the Axxis Pads
Make herendious "howling" noise at low speeds, not squeeking, "howling" !!
1. how do i fix that?
2. is it fixable?
3. if I need differnt pads what do you think?
4. were they installed wrong or missing something like shim or greese....
has this happened to anyone with these pads? .... just anything to help me try to fix it. thanks
2. is it fixable?
Is it like a whirring noise? If so that's normal for a slotted rotor, they will make noise. Axxis are good, they dust a lot though, and when they get thin expect to boil your fluid. The pads also can be noisy at times. Did you brake them in properly? I try and take it easy on them for 500miles in order for all pad material to transfer etc.
it is like a large "howel" it is not a quite noise...or a "noise" it is a howel that is very loud.... everything is functually well.... and they stop great... but the trouble is when im going less than 5 miles / hour. and just coming to a complete stop... just loud loud howel. doesnt do it all the time... but it does do it pretty consistantly.
