Tanabe Medallion Touing Exhaust
Hey guys was planning on purchasing this exhaust. What Test Pipe do you recommend. Not sure between 60mm or 63.5 or something else? I am pretty sure the exhasut piping on the Tanabe is 60mm?
Is the flash pro needed after a test pipe and exhaust? I wanted to get it but a later time. Will I be ok without it I the meantime?
Give it a test and see.
Mine ran weak before secondary cam, yes had flat spots. 2.0L / 9k rpm
I made a 44mm and installed<in the 50mm area> restriction plate in RH side to give a little restriction,+ increased torque , it worked well pulling to 9k with no flat spots.
Tried a few options to lessen noise .have installed a 25mm extensions in the muffler. Tanabe Concept G.
hellaSleepy
Apr 14, 2011 08:04 AM
