trouble with hasport diff mounts
well the other day I installed the hasport 70a differential mounts and today i was having alot clunking and vibrations. so i decided to raise up the car and look at the mounts and make sure that they were installed correctly. So I began to remove the rear mounts and the driver side came out fine but the passenger side was really hard to remove. after about an hour of pulling and yanking I finally was able to take out the mount and when I did, I saw this... no wonder it was soo hard to remove. That metal is suppose to be pressed in with a machine...Now I can't take out that metal thats stuck on the differential and I cant put the mount back in either. My car is stuck on 4 jack stands
This is how its suppose to look like..
pb blaster inside the collar, grip the outside with a set of vice grips and use a prybar to work the piece off the diff mount. Then get a giant c clamp to press the collar back into the hasport mount (get some master flex polyurethane grease from autozone and coat the outside of the collar with it prior to install).
RickyLee
Apr 27, 2015 03:50 PM
