Sponsored by: CARiD
will spoon IK24 racing plugs work on S2000?
Old Oct 21, 2009 | 12:08 PM
Boomer22's Avatar
Default will spoon IK24 racing plugs work on S2000?
will they? I can get them 4 free
Old Oct 21, 2009 | 12:28 PM
AP1ChowFun's Avatar
send me a free set and I'll let you kno.
Old Oct 21, 2009 | 02:03 PM
Vik2000's Avatar
me too. pm me for detailed address.
Old Oct 21, 2009 | 07:26 PM
deathsled's Avatar
damn you guys are greedy! he probably means someone has a set they're willing to let him have
Old Oct 21, 2009 | 08:41 PM
gospeedgo1's Avatar
denso iridium for an s2000 is normally IK22 according to denso's website. IK24 is 1 step colder according to information i have read.
http://www.densoiridium.com/find_part.php
Q. Why are there different heat ranges? Which one should I use?
A. Part of your spark plug’s responsibilities, in addition to firing a spark, is to remove heat from the combustion chamber. This is accomplished by channeling the heat through the insulator material and metal housing. From there, the heat is transferred to the cylinder head where the engine cooling system can go to work. A spark plug’s heat range is its ability to dissipate heat. The “colder” the plug, the more heat it can channel out of the combustion chamber. In a performance application, colder heat ranges may be necessary to handle the extreme temperatures brought on by higher compression ratios, forced induction, and high RPM’s. While “Colder” plugs may seem to be the way to go, please remember that the spark plug must achieve its “self-cleaning” temperature where it can burn off fuel and carbon deposits. Otherwise, the plug could “foul out” where it is prone to misfiring and poor acceleration. A plug that is too “hot” can overheat, also causing power loss, detonation, pre-ignition, and possible engine damage. A good, general rule of thumb is to start with the factory recommended heat range. For every 75 to 100 hp you add to your engine, you may go to the next colder step. DENSO heat ranges move up as they get colder; 16 would be our hottest Iridium Power plug, 34 would be our coldest (ranges; 16,20,22,24,27,31,34)
Old Oct 22, 2009 | 01:42 AM
nzmac's Avatar
We use them here, no issues. Just double check with feelers before installing.
Old Oct 22, 2009 | 06:26 AM
Sinji's Avatar
I use the ik24 on my boosted s2k. i've used them without any problems on my n/a ones also
Old Oct 29, 2009 | 10:06 AM
AlexS2200's Avatar
From: 13851 A Better Way #11D, Garden Grove, CA 92843
I know I'm late but, Yes, spoon IK24 work for s2k. I've used them.
Old Oct 29, 2009 | 12:43 PM
AJ PwR's Avatar
I used to run them as well but I ended up with NGK IRIWAY instead because they have the same performance, a lil cheaper and last longer.
KaNgArOo
Feb 22, 2015 10:55 AM
Silver&stoned
May 21, 2014 07:54 PM
VAD
Apr 30, 2010 04:13 PM
Subaru2000
Jun 3, 2003 09:46 AM
Destiny2002
May 23, 2002 08:03 PM
