S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
2004 FLASHPRO?
Old Feb 29, 2012 | 08:45 AM
hondavet's Avatar
Default 2004 FLASHPRO?
Hey guys,
Sorry for the misleading title. I was wondering if there was an option to make a pre 06 s2k have the same midrange power as an 06+ with testpipe and flashpro? Without getting something like the super expensive aem standalone lol I already have a test pipe.
Old Feb 29, 2012 | 08:55 AM
Redline S2K's Avatar
You could try a Apexi VAFC but it won't produce the same results as a true standalone. Out of all the choices for a pre06, I do beleive AEM is the cheapest, but still very effective. I just got tuned on it and made the numbers in my sig. You can find used AEM v1's for around 600-900 but you'll have to get the modifry fix for your temp gauge.
Old Feb 29, 2012 | 10:56 AM
JUSTINTHECOASTIE's Avatar
Try the vafc 2, I made 224whp with only a test pipe tuned on the vafc 2
Old Feb 29, 2012 | 01:25 PM
thomsbrain's Avatar
Hondata's pre-2006 option was called the K-Pro.
Old Mar 1, 2012 | 10:04 AM
deepbluejh's Avatar
Doesn't the VAFC only *remove* fuel, not add it? If that's the case, you're just leaning out your A:F ratio - which will get worse with mods, not better.
KPRO is definitely what you want.
Old Mar 1, 2012 | 06:55 PM
Yes but a fuel pressure regulator can add it, use the vafc to lean out; EMS for bolt ons is overkill
Cwazy Cwis
May 19, 2013 01:13 PM
abnormals2k
Nov 11, 2010 10:40 AM
WongGahming
Dec 17, 2004 06:21 AM
beroznikmal
Jun 23, 2003 07:17 AM
Xplosiv
May 22, 2003 07:05 PM
