3" or 4" cai
#181
I built a 3.5" custom ram intake this weekend however I'm noticing a loud vibration which could possibly be my air filter hitting the felt liner on the bottom of the hood. This only seems to happen when I rev over 6k rpm. I used an old k&n fipk air box and think I might be able to make more room by cutting a slightly larger hole to allow the intake to ride lower.
Will this be a long term problem if the filter continues to hit the liner or could I put some padding on the liner to reduce the vibration?
Or does anyone have a suggestion for a lower profile filter cone? I'm using a 6" AEM filter.
#182
I am using the K&N airbox for mine as well. The Filter sits about level with the top of the box. I did modify the elbow bracket that held the K&N intake arm to fit the 3.5" intake. I do not have rubbing issues, I also do not have the hood liner installed.
I don't have an image straight on from the front of the car, but you can get a feel for what is happening from this photo.
#183
#185
#186
#187
Mounting hole elongated:
My parts list is provided by another member (page 4 of this thread), following in his footprints:
Item List:
- AEM Dry Flow Filter p/n 21-210EDK
- Vibrant Velocity Stack, Aluminum (3.5" Inlet O.D., 6" Bellmouth O.D.) p/n 10952
- Vibrant 16mm O.D. Vacuum Line Fitting p/n 2896
- Vibrant 4 Ply Reducer Coupling, 3" x 3.5" x 3" long p/n 2774
- Vibrant 4 Ply Silicone Sleeve, 3.5" I.D. x 3" long - Black p/n 2716
- 3.5" 90 degree L intercooler tube
Thanks for the info.
#189
The elbow is in this picture with the hose clamp on the K&N intake arm by the airbox, I had to elongate the mounting hole to allow it to sit lower. Mounting hole elongated: My parts list is provided by another member (page 4 of this thread), following in his footprints: Thanks for the info.
#190
