Boring a stock block
I'm in the middle of an NA project motor and need to have the machining work done. With the sstock block having FRM cylinder walls, does that mean that you cannot bore the stock block out and can ONLY sleeve it?
Thanks for your help!
you can bore it, pistons are only available up to 0.25mm oversize though. Piston to wall clearance on an NA motor needs to be 0.001 to 0.0015" inches.
You should have your machine shop contact the manufacturer of their honing equipment to obtain the proper stones. The process is just like anything else, just needs finer stones. The block bores very well on a standard boring bar.
Lmk if you need any pistons
Every s2000 block I have seen needed to be bored to get the bores straight/round. Some are pretty close to round but they are always tapered pretty bad. I have 2 that were too ovaled to even use 0.25mm oversize pistons.
take a look at inlinepro machining services to get an idea what to ask for, the S2000 experts, here is a link for ya
http://www.inlinepro.com/s1/c-23-engine-builds.aspx
