S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
High compression valves
Old Jul 9, 2012 | 04:53 AM
yas2000's Avatar
Default High compression valves
Hi all,
As I am one of the NA hp desperate seekers, I came across blox racing's f20 high compression valves. Basically they are designed with a flat bottom in order to increase cylinder compression and they are lighter than stock valves.
Has any one tried them or know some one who did?
Your feedback is much appreciated.
This is the link to the website.
http://www.bloxracing.com/bloxshop/i...product_id=472
Old Jul 9, 2012 | 04:29 PM
tidus888's Avatar
just use a thinner head gasket or something... spoon has it!
Old Jul 10, 2012 | 05:09 AM
yas2000's Avatar
thanks for the feedback, we have 98 octane at the pumps here, would it be fine if i go for both the gasket and the valves in terms of timing and clearance.
thanks,
Old Jul 10, 2012 | 05:11 PM
wadzii's Avatar
Banned
mill the head.. way cheaper than valves and a spoon headgasket.
You can mill up to about 0.025 w/o running into clearance issues. That will increase the compression by 2 points, from 11:1 to 13:1
Old Aug 4, 2012 | 09:06 AM
AlexS2200's Avatar
From: 13851 A Better Way #11D, Garden Grove, CA 92843
^DO NOT MILL the HEAD! You will change cam and crank timing. Unless you want to buy Toda 900 dollar adj cam gears to degree the cams and crank in again, I highly recommend against this. 2 layer gaskets are no good too because of this. High comp valves are good but it will only gain you a little, more likely it will just bring compression back closer to stock because I'm sure you motor has lost some over time of use.
Old Aug 4, 2012 | 09:14 AM
wadzii's Avatar
Banned
Milling the head 0.020 will change the can timing by less than 2 degrees... not really enough to change things..
dan_uk
28
Jan 16, 2012 12:24 AM
Vladimir L
Mar 9, 2006 04:11 PM
Vladimir L
Feb 2, 2006 06:11 AM
Prolene
Sep 22, 2003 09:01 PM
Pixsurguy
Oct 31, 2002 09:40 AM
