Head gasket
Old Jan 30, 2006 | 12:52 PM
Vladimir L's Avatar
Default Head gasket
How much will using a 3mm head gasket raise my compression by? Will it be enough to use toda b's.
Old Jan 30, 2006 | 12:57 PM
Vladimir L's Avatar
http://www.inlinefour.com/spoons2headg.html
Old Jan 30, 2006 | 01:01 PM
xviper's Avatar
I think you've got it backwards here. The Spoon gasket is "thinner" than stock and thus, will RAISE compression. You are putting in a much thicker gasket (actually, 3 times thicker). You will DECREASE compression.
Old Jan 30, 2006 | 05:51 PM
XclusiveAutosports's Avatar
A 3mm head gasket will LOWER your compression to around 9:1, not raise it.
Old Jan 31, 2006 | 12:11 AM
Vladimir L's Avatar
How about the spoon one how much higher will it make it
Old Feb 1, 2006 | 01:07 AM
slipstream444's Avatar
I think it bumps it up by 0.5
Old Feb 1, 2006 | 05:46 PM
kurt_bradley's Avatar
From the link at inlinefour
Looking for a quick fix to raise compression on your S2000? Look no further, Spoon's thin headgasket for the S2000 is .45mm thinner than the stock headgasket which is .75mm. You can expect a slight raise in compression of about .3 which will add a bit more low-end torque. This gasket also has better sealing properties than factory and is also more durable.
Old Feb 1, 2006 | 08:00 PM
rmc22's Avatar
Hmm... Anyone have the Spoon head gasket with comments?
Old Feb 2, 2006 | 06:11 AM
mxt_77's Avatar
Toda does not recommend using a thinner than stock headgasket with their cams if you are using stock pistons.
WRX2S2K
Dec 31, 2012 09:49 PM
TRBOKEV
Dec 21, 2010 02:22 PM
chubbys2k
Jan 10, 2010 09:02 AM
Vladimir L
Mar 9, 2006 04:11 PM
SuzukaS2K
May 16, 2003 10:00 AM
