Kpro - Stock
Originally Posted by Balance_Point,Apr 9 2009, 11:19 PM
I had the understanding the immobilzer no longer functioned which might not be a big deal to some, but others...... Am I incorrect?
Originally Posted by geoffrey06,Apr 3 2009, 10:39 PM
I have to disagree with this... You can pick up decent power from a tune. It may not always show with the peak numbers, but its under the curve that counts. Your mid range will feel a lot stronger if you have a decent tuner.
Also, for the ap2 guys, you never have to worry about shifting out of vtec again.. With a good header, the vtec will normally end up ~5k rpm.
the earlier ap1's do a little better from what i've read because of the rich a/f in stock trim.
Originally Posted by thesilverbullet,Apr 19 2009, 08:56 AM
not w/ 06+ ap2's - you can look at hondata own dyno (stock reflash) - they got ~zero peak gains with just the ecu and only made gains where they lowered vtec.
The MY00 and MY01's had the problem with running too rich, they fixed this problem mostly with the 02-03 ecu.
