Map sensor question
Hey everyone i had alil question, i am running a vortech kit with 10 psi and its maxing out my map sensor apparently, is there a map sensor out there that i dont have to tune or buy a new ecu for thats better then oem? also anyone else have bogging issues with the skunk2 tb? just put my 68 mm on today and it excelerates just fine and drives just fine, but bogs and backfires alil went i left off the gas and occasionally dies, granted it could be due to the tps sensor needing adjusting, anyone have this issue?
Why is this in the N/A section? Your boosting so you'll probably get better responses in the forced induction section.
I'm not familiar with the supercharger kits and their EMS's but if you didn't adjust the TPS when you installed the bigger throttle body it'll do exactly what it's doing. So calibrate the TPS, and if the EMS will let you, you'll need to add some fuel to the throttle tip in, along with adjusting the tune itself.
