MOTUL OIL
#21
First is from 8100 5W30
Second is from 300V.
300V is also dyno proven to slightly improve HP.
Other things to note, is that the 300V was run for a 5500 mile interval, with copious amounts of extended VTEC; my Oil Change indicator was showing 5% when I changed my oil (I was slightly nervous about this, but had faith in the product).
Also, note that the oil had ZERO breakdown/shear. 8100 resisted breakdown better than the conventional oil used before, but 300V was rock solid.
#23
OEM Air Filter, and I do have a dyno, but my dyno is inconclusive as to the oil as my first baseline was at 700 miles, and the second dyno was around 17000 (break-in) The gain would be a combination of the break-in and the oil, although I cannot give a further breakdown of what each one did without some additional dynoing and an oil change on the dyno.
Airbox cover on and off did not make a difference on the dyno (but Shawn does have a HUGE fan which moves an insane amount of air).
per:
http://www.sportrider.com/tech/146_0310_oil/index.html
per:
#29
Originally Posted by psychoazn,Apr 23 2009, 02:17 PM
Probably a contributing factor to the cost....
