1/4 Et
Ive been noticing that people with SC S2k's have not been gettin solid 1/4 Et
Granted the car is not constructed for straightline speed........
Shouldn't a SC S2k run a high 12 ? Even if most of the power is at the top end .........
How do the SC s2k pull ?
The rearend is not strong enough to hold up to repeatedly launching with the power an SC S2000 makes. Most people do not go all out and launch an SC S2000 hard at the track, mainly because of horror stories they've heard from people such as myself. The combination of the SC, upgraded clutch, the stock rearend, and a high RPM launch is mostly good for breaking at the line. A turbo S2000 is a little different of a story because it makes enough power low in the RPM range to get it moving without having to shock the rear end with a hgih RPM clutch dump.
What about the theory that if the tires are spinning upon launch, then you're better off than if they stick (better for the diff).
I would think that any high RPM clutch drop would be bad, but I guess the tires spinning would be the better of the two scenarios, right?
That's the difference between bench racing and the real deal. Unless you want to break stuff, the car won't do those numbers at the track...more than once or twice. Wes knows what he's talking about through the pain of the wallet.
