2010 S2K Challenge Series Schedule/Rules
Old Jan 15, 2010 | 09:39 AM
600rr_rocket's Avatar
Talking 2010 S2K Challenge Series Schedule/Rules
Welcome to another exciting season of the S2K Challenge Series! The 2009 season was a huge success, with higher than expected attendance at all of our events. Just prior to the 2010 season, current/potential participants "gathered" on a thread on S2KI.com to modify last year's rules to better reflect a more even playing-field for the four classes: Stock, Street, Modified, and Unlimited. Thanks to everyone for their participating in the discussion to ensure a more competitive and exciting Series.
Updated 2010 schedule:
1/31 - Buttonwillow #13 Results
2/20 - WSIR Results
4/11 - Buttonwillow #13 Results
5/16 - Spring Mountain Results
6/13 - WSIR Results
7/10 - Laguna Seca Results
8/15 - ACS Roval Results
9/26 - Buttonwillow #13 Results
10/23 - Buttonwillow #13 Results
11/7 - SOW (CCW) Results
12/4 - SOW (CW) Sign up now!!!
Participants can choose their top 9 out of the 11 events during the year to contribute to their total score. The points system will be adapted from the Formula 1 Series:
1st: 10
2nd: 8
3rd: 6
4th: 5
5th: 4
6th: 3
7th: 2
8th: 1
CHEERS TO ANOTHER EXCITING SEASON!!!
Link to last year's Series: https://www.s2ki.com/forums/index.php?showtopic=665071
Old Jan 15, 2010 | 09:40 AM
2010 S2K Challenge Series OFFICIAL RULES
AERO
0.25* = air dam bumper, air dam or any add-on lip excluding non-CR OEM lip.
0.50* = full front aero package (air dam bumper, lip, canards, splitter, wheel spats, etc.)
0.25 = rear diffuser
0.25 = Non OEM or modified rear bumper
0.25 = rear spoiler (none-OEM)
0.50 = level 1 wing (CR wing or smaller)
1.00 = level 2 wing (APR GTC-200 wing or smaller)
1.50 = level 2 wing with riser (APR GTC-200 wing with riser)
2.00 = level 3 wing (any adjustable wing bigger than APR GTC-200)
TIRE/WHEEL
2.50 = R-compound tires (NT01, RA1, R888, A048, PSC)
3.50 = R-compound tires (R6, V700, R1)
5.00 = R-compound tires (V710, A6, C91)
0.50 = any deviation from original OEM staggered wheel setup up to 9" wide front and/or rear.
0.75 = any deviation from original OEM staggered wheel setup wider than 9" front and/or rear.
0.75 = 245-255 front tire
1.00 = 265+ front tire
0.25 = 265+ rear tire
POWER
0.25 = OEM 2.2L motor
0.25 = any aftermarket intake system or modification to OEM intake
0.25 = any aftermarket header
0.25 = test pipe
0.25 = cat-back exhaust
1.50 = engine internal modifications (non-performance enhancing modifications excluded)
2.50 = forced induction (inclusive of ECU, header and intake modifications)
0.75 = aftermarket ECU, ECU reflash or OEM ECU swap
SUSPENSION
1.00 = fixed-height none-adjustable shocks with up to 400lbs/in spring (including CR shock and spring).
2.00 = adjustable shocks or coilover suspension
DRIVE TRAIN
0.50 = non-OEM LSD
WEIGHT
0.25 = soft top removal + hardtop
0.25 = passenger seat removal
0.25 = rear trim removal (unless necessary for installation of safety equipment)
0.25 = light weight doors
0.25 = AC/audio removal
FREE MOD
- any TW140+ street tires
- lightweight battery
- lightweight hood, trunk, fender
- spare tire & tool removal
- any alignment
- camber kit, bump steer kit, tie rod end, roll center adjuster
- updating or backdating anything except CR performance-enhancing parts
- bucket seats
- steering wheel
- brake duct
- aftermarket brake systems
- any sway bars
- any add-on chassis reinforcement
- any interior removal as required for safety equipment installation
- high-flow catalytic converter
- any spacer
- OEM spoiler
SAFETY (applies to Modified and Street classes only, and all must be able to pass SCCA inspection)
-0.25** = roll bar installation
-0.50** = roll bar installation with bucket seat and FIA-approved 5+ point harness
-0.75** = full roll cage installation with bucket seat and FIA-approved 5+ point harness
OTHER
- ANY more interior / exterior removal than specifically allowed above will result in Unlimited classification (including bumper beams)
- no NOS allowed in the competition
* Mutually exclusive. An air dam bumper or aftermarket lip would be 0.25 points. Upon addition of a splitter or any other front aero modification, the total point penalty would be 0.50 points.
** Mutually exclusive. There is no point deduction for running only bucket seats and harnesses without a roll bar.
Stock Class - 0.50 points maximum
The purpose of this class is to keep costs down and be attractive to a newcomer with a completely stock S2000. Drivers of all experience levels are welcome. As the rules are most tightly regulated, all the cars would be on the same playing field and direct driver to driver comparisons could be drawn. Tires are restricted to TW 140+ and no larger than 235/40/17 front and no larger than 255/40/17 rear. No splitter or wing allowed.
Street Class - 3.50 points maximum
The purpose of this class is to allow moderate modifications to the car, as well as allowing CR owners the ability to truly "arrive and drive." A bone-stock CR with AC/Audio removal would be classed at 2.5 points, allowing CR owners the ability to do an ECU tune, add a diffuser, wheels or do some minor power modifications. The modifications limits would be: no front splitter, no level 3 wing, no tires less than 140 treadwear, no final drive, and no FI.
Modified – 10 points maximum
Unlimited – No point limit
This is an exhibition class. No holds bar!
Old Jan 15, 2010 | 09:43 AM
The 2010 S2K Challenge Series is on Facebook! Please add yourself to the group for event updates, writeups, etc.
http://www.facebook.com/group.php?v=wall&r...id=251866941405
Old Jan 15, 2010 | 09:52 AM
Please do not add any replies...this thread will be Stickied...thank you!
Old Feb 8, 2010 | 01:19 PM
The 2010 Schedule is now updated!
Old Mar 10, 2010 | 11:26 AM
ETKMS's Avatar
why nothing on the east cost? maybe in Flroida oneday?
Old Apr 15, 2010 | 10:49 AM
klch's Avatar
Do you think you could post the links of the results threads here? like you did last year.
Thanks.
Old Apr 16, 2010 | 07:45 AM
Richard EVO's Avatar
Why assign 2.5 points to R-compound tires like NT-01, and then say you can't run them in Street Class, which allows 3.50 points?
I have a totally bone stock AP1. My only Mod is NT-01 tires. So I have a total of 2.50 points, but I can't run street class, I have to run Modified, where everybody has power mods, suspension and aero.
I think that's unfair and I'd like to ask for a rule change. Street class is 3.50 points maximum. No additional restriction on tires. Can I get a ruling on this? Thanks.
Old Apr 16, 2010 | 10:17 AM
VitaRenovatio's Avatar
I argued for the same thing, under the same logic. But it fell on deaf ears. We actually allowed NT01 last year in Street Class, but this year they banned it. Ask BellWilliam why--I forget the reason, but he was the major proponent of banning it, I think.
Old Apr 16, 2010 | 10:23 AM
^^^ William loaned me a set of AP2 wheels to run on my AP1, and advised me what size of NT-01s to buy, which I bought a couple of days ago. Then he tells me this morning I can't run Street Class with these tires. I think he's yanking my chain. There's no way I can compete in Modified when my car is absolutely bone stock except for the tires.
If the rulemakers really believe that their point system makes sense, and that NT-01 should be 2.50 points, and that all other mods are properly assigned points, then it shouldn't matter how I get to a maximum of 3.50 points, I should be able to run Street.
