2012 PAX indices posted
Originally Posted by jadrice' timestamp='1322856788' post='21205464
[quote name='CKit' timestamp='1322842977' post='21204619']
I've autocrossed on the stock CR shocks and on the Motons. I personally think the adjustability in different conditions is a big part of the benefit. The other part is the effective increase in spring rate you can get with the nitrogen pressure in the reservoirs. Personally, I think there is a big difference for high grip surfaces where extra spring is a good thing.
When conditions are loose, no real advantage (except adjustability) over stock shocks.
[/quote]
Matt, I think we've done more adaptation to our driving style per surface change on the fly, but the car seems to be pretty consistent or close to it across the board.
Yeah, you always have to adapt driving style. That's part of the fun/challenge and why 3 runs help separate the adaptable from the boys. I just don't like driving around a car I feel is not 100%. For example, I thought my car was a touch pushy at Lincoln. A month later, it was loose as a goose at Blytheville. I mean, I had to wait for ever to get on the throttle out of a corner. It took 6 runs to finally adjust the shocks to the point where the car worked.
In this case, Lincoln was super grippy from all the rubber laid down. If I got on the gas early, the front would just push. In Blytheville, the lot was dirty and cold (we ran first) and there just wasn't any way for me to use the gas on exit without getting sideways.
Originally Posted by jeffjanzen' timestamp='1322694210' post='21199212
I'm still not convinced fancy shocks make the car any better.
I'm with Matt - my car feels different on every surface. I love the balance at home, but it gets quite pushy in Lincoln.
I recommend NOT setting a car like this for Nationals!
Back to PAX, I really hope the Pro Index helps as well. Making the car better suited for launching makes me more interested in Pros. The competition will keep certainly times tight and the sandbagging out.
-Marc
That was also before STR.
In STR you don't need the shocks to act as extra springs you can change the springs to suit the surface. You can buy a lot of springs for the cost of a set of Motons.
Originally Posted by PedalFaster' timestamp='1322781839' post='21202811
Before the AP2 and autocross-valved Koni Yellows came along, high-end shocks with a ton of rebound damping were considered mandatory for a fully prepped car. . . .
We've had an SSM S2000 on 1000# springs since 2008... but it also has Motons, lol.
I don't know who you were talking to, but I don't recall anyone ever laughing at the CR for any reason other than its appearance. The SAC/SEB placed the car in with the standard model with the warning that it would be monitored closely. I still don't see how a car with stiffer springs and swaybars and lower weight could not be a better performing car. You can claim it's not much better, but how much is "not much" when you're driving a standard model and just got beat by someone with a CR?
Originally Posted by sirbunz' timestamp='1322366236' post='21187890
The CR was laughed at for many other reasons as I have posted before.
-Marc
CKit
Jan 23, 2012 04:54 PM
