245 or 265
Old Jul 27, 2009 | 11:53 AM
josh7owens's Avatar
Default 245 or 265
should I run kumho v710 245/45r/16 or 265/45r/16 on my stock ap1 rear wheels? I'm running A-stock.
Old Jul 28, 2009 | 03:37 AM
IMP's Avatar
IMP
https://www.s2ki.com/forums/index.php?showtopic=172595
Old Jul 28, 2009 | 10:37 AM
SumAznGuy's Avatar
That link isn't really up to date anymore.
Personally, I say got with 245/45/16 front and rear.
With the bigger front bar, the 245 setup will help the car rotate better on lower speed sections.
Haven't tried the 245 V710's with 265 rears so I can't say how those will work, but I am really happy with the 245 A6's.
Old Jul 29, 2009 | 06:42 AM
josh7owens's Avatar
245 a6's all the way around? hasnt most nationals been won on a stagger set up
Old Jul 29, 2009 | 06:58 AM
SumAznGuy's Avatar
Last year's runner up AP1 car was on 245 A6's all the way around on stock wheels and a "dump" exhaust and the Grendron hollow bar.
The 2007 winning AP1 car was fully prepped on 245 A6's all around.
The theory is that you need the big front bar to keep the wheel lift on check. When you have sticky sticky front tires, and the soft front springs on the S, you will get rear wheel lift like those VW's. Since the S is rwd, the wheel off the ground will turn the car's HLSD to work as an open diff and you end up sending power to the wheel with the least resistence (ie wheel in the air) which in turn slows you down.
Since the bigger bar will also make the car more prone to understeer, having a staggered tire setup will make the understeer worse on the AP1. I'm not too familar with the AP2, so someone else can chime in on this.
Another thing you can do for setup is change your alignment settings, taking away some of the rear toe-in to help initial turn in. This will make the car rotate better on lower speed stuff, but you might sacrifice higher speed stability with this set up.
Old Jul 29, 2009 | 07:23 AM
josh7owens's Avatar
ok thanks
Old Jul 29, 2009 | 07:59 AM
wing's Avatar
I've tried both setups with V710's 245/265 and 245/245 and the non-staggered is faster for me as SumAznGuy mentioned it is mostly because in the lower speed stuff the car can rotate instead of plow like it always seemed to do before.
Trail braking is more noticeable now.
Old Jul 29, 2009 | 08:04 AM
josh7owens's Avatar
so run 245's in the front and 245's in the back? with the hollow 1.375" bar?
Old Jul 29, 2009 | 08:09 AM
krazik's Avatar
Administrator
when did the switch to hollow front bars happen? everyone used to run 1.25" solid.
Old Jul 29, 2009 | 08:47 AM
SumAznGuy's Avatar
Switch to a 1.375 hollow was about 2 years ago.
This year, a few guys including me (not that I am fast or anything) jumped ship to the 1.5 hollow ARE bar.
