245 or 265
Originally Posted by PedalFaster,Aug 2 2009, 03:08 PM
That's pretty much exactly in line with what's posted in the FAQ, except with more camber. The FAQ's settings assume max-ing out the front camber (I should make that more explicit), and it appears your car can get more than most.
[QUOTE]2.1.3 ALIGNMENT
A proper alignment is important for autocrossing, and compared to the other changes you'll be making, a bargain at less than $100. Individual alignments vary, but for the AP1 cars, the general consensus falls in the following ranges:
Originally Posted by jeffjanzen,Aug 2 2009, 02:05 PM
Most AP1s I know of are limited to about 1.8 up front but I could almost get 2.0 so that's the limit I posted. I've never heard of one being stuck with 1.5. That would suck.
Personally - I take internet alignments with a grain of salt. They provide a nice place to start from. But I can guarantee that you'll probably be changing it after one or two events.
Alignment racks are very much like dyno's - there is so much that goes into calibration, laser leveling, and manufacturer designs that makes it very very hard to compare from one rack to another.
1.6 on my rack could be 2.0 on yours... etc etc. The biggest thing you want to note is the split between front and rear camber and then what happens when you make a .2deg change in one direction or another.
True. Fortunately, the recipe for the S is to max out the front and adjust the rear relative to that, so actual readings don't matter much. But it is good to know if you're in the ballpark.
A friend of mine had his AP2 done recently, and ended up with -1.0 in the front. The mechanic said that's all he could get, but just looking at the adjusters you could see there was more room to go. Had he known he was supposed to get -1.5+, things might have turned out differently.
Sounds like the ranges I posted should be widened a bit before they go into the FAQ anyway.
