245 F / 255 R alignment specs
Just bought a set of star specs 245 front 255 rear. I was running 255x4 NT-05's (which have a stiffer sidewall) with -2.6F, -2.8R and 0 rear toe. Believe it or not but I was getting a fair amount of understeer with that setup, especially in corner exit, no matter how I played with the compression/rebound.
Would like suggestions for alighnment specs for daily driving with 6-8 track days a year. Ive got skunk2 pro-c's which the springs are 10k F&R I believe.
op, what's your current alignment settings? Hard to give you suggestions without knowing what was understeering with 255x4. Since you were understeering an upgraded front sway bar would make it worse unless accompanied by new alignment settings.
Don't know now since ive played with the suspension quite a bit. could have also been my rideheight (rear was a little lower than the front). Ive now raised the back end 1/4" above the front. I think that'll help quite a bit. Thinking of running -2.8 F, -2.5 R with 1/8" of rear toe.
You say "daily driver" in the op so -2.8 will wear out your tires much quicker since they're rolling on the inside shoulder. You may want to start with max negative camber you can get with the stock adjusters which would be around -2 up front (I'd then recommend -2 at all 4 corners).
michaelnyden
May 27, 2015 09:15 PM
P-CarDriver
Mar 22, 2008 05:29 PM
