255's all around, understeer/oversteer
Originally Posted by WynnS123,Feb 13 2010, 03:08 PM
So can the KW V3's stock valving handle a 628# spring? If so, would it be favorable for me to change my factory springs (515# all around) to a 628# spring? I'm also running a nonstaggered 255 set up at the moment with a Saner bar on the middle hole. I'm currently running on street tires (Star Specs), but would like to jump up to NT-01's in 275/40/17. My 515# springs would probably be too soft for this setup.
The car is really well balanced at the moment and I'm reluctant to change anything, but I know I need stiffer springs to run r comps. If the V3's can handle a 628# spring then I may just go that route.
Originally Posted by Billj747,Feb 14 2010, 08:15 AM
I might suggest going with 628lb front 571lb rear to put a spring rate stagger in your car in addition to your saner bar. If you are indeed going to 275/275, I might reccomend 628/628, but I have not tested that tire package. I still might go with 628/571.
If I end up going 275's all around, I'll pick up the 6ULR wheels in 17x10 +52.
Originally Posted by Billj747,Feb 13 2010, 02:49 PM
Damper settings make a big difference but having an extra degree of rear camber more than mark is HUGE. I would say that much rear camber greatly increases rear grip and stability but would probably also increase tire wear on the street.
Toe has much more of an effect on tire wear than camber...
Right now we have 12k all around on our Challenge Comp + dampers with 255s all around and OEM AP2 sway bars. so far the car has very even tire wear and is very well balanced but with a slight edge toward oversteer, which i like. We run about -3.25 front and -2.75 rear camber most of the time. We may put the rear at around 3 here durring testing.
Shift9303
Jun 26, 2018 11:17 AM
