AIM Integration to AEM EMS
http://www.aimsports.com/products/AEM-digi...play/index.html
AIM promised this about 3 years ago. Finally delivered. I wish it was for the Race Technolgoy DL-1 though.
Originally Posted by jzr,Oct 26 2006, 04:55 PM
It's simple enough to do with the DL1, you just have to wire it yourself. Only took a few extra minutes to run the wires for TPS, RPM, and knock when I did the SAFC install.
I'll be installing my DL-1 later this winter. Mind if I ping you with questions when I get around to setting it up?
Originally Posted by msm_s2k,Oct 26 2006, 04:29 PM
I've heard from others that it's a PIA; though I think you're the first person I'm aware of that has actually done it.
From a driver perspective, the throttle position sensor has been very fun to look at in post-race data analysis. My next build will be a bit more complex, and I think it will be interesting to look at it from a tuner perspective to see how the boost is reponding and how the AFR is holding up around the course.
I documented all of the wiring connection for hooking up the sensors to a DL1 in another thread. https://www.s2ki.com/forums/index.php?showtopic=400862
Originally Posted by Nobody,Oct 29 2006, 12:03 AM
Check out www.guage-tech.com. Pretty awesome.
http://www.gauge-tech.com/
