AIM Integration to AEM EMS
Old Oct 25, 2006 | 07:27 PM
msm_s2k's Avatar
Default AIM Integration to AEM EMS
http://www.aimsports.com/products/AEM-digi...play/index.html
AIM promised this about 3 years ago. Finally delivered. I wish it was for the Race Technolgoy DL-1 though.
Old Oct 26, 2006 | 03:55 PM
jzr's Avatar
jzr
It's simple enough to do with the DL1, you just have to wire it yourself. Only took a few extra minutes to run the wires for TPS, RPM, and knock when I did the SAFC install.
Old Oct 26, 2006 | 04:29 PM
msm_s2k's Avatar
I've heard from others that it's a PIA; though I think you're the first person I'm aware of that has actually done it.
I'll be installing my DL-1 later this winter. Mind if I ping you with questions when I get around to setting it up?
Old Oct 26, 2006 | 05:05 PM
Nobody's Avatar
Anyone want to buy my gauge-tech display and my Racepack G2X so I can score AIMs $1799 setup???
Old Oct 26, 2006 | 05:30 PM
jzr's Avatar
jzr
No problem. Most automotive sensors operate on either a 5 volt or 12 volt scale. All you have to do is locate their wires, and tap them into the 5V or 12V inputs on the DL1. It's easier if you're already down in there doing something with the ECU, like installing an AEM EMS or SAFC.
From a driver perspective, the throttle position sensor has been very fun to look at in post-race data analysis. My next build will be a bit more complex, and I think it will be interesting to look at it from a tuner perspective to see how the boost is reponding and how the AFR is holding up around the course.
Old Oct 28, 2006 | 07:41 PM
news2kroller's Avatar
has anyone tried the lower end displays? i have aem ems and i would love to have one of these but i wouldnt need anything other than the base model. any feedback if great. thanks
CHRIS.
Old Oct 28, 2006 | 10:03 PM
Nobody's Avatar
Check out www.guage-tech.com. Pretty awesome.
Old Oct 28, 2006 | 11:47 PM
cthree's Avatar
Administrator
I documented all of the wiring connection for hooking up the sensors to a DL1 in another thread. https://www.s2ki.com/forums/index.php?showtopic=400862
Old Oct 29, 2006 | 06:37 AM
msm_s2k's Avatar
Great, thank you!
Old Oct 29, 2006 | 04:01 PM
robinson's Avatar
here is the corrected link
http://www.gauge-tech.com/
kaissi
May 23, 2010 12:52 PM
skool u
Apr 22, 2010 12:03 PM
skool u
Apr 11, 2010 05:17 AM
kaissi
Apr 3, 2010 09:17 PM
sigmanin
Nov 9, 2009 11:43 PM
